Creating file after a number of measurements
Dear
We are Floris Vande Walle and Nico Vandendriessche. For our graduation project, we need adjust the hydraulic suspension on a self propelled sprayer. To do this, we need a correct measurement of the pressures inside the hydraulic pistons.
Our problem starts with the following:
We use a Arduino Mega to measure 6 different sensors. (Analog input) It measures 48 times a second. To make a graph in M.O. Excel, we can only use a column of 1.048.000 values. After measuring for one hour, it would exceed this amount.
Is it possible, with a Arduino Mega board, to make a new file every hour? And if possible, how do we do this? Is there a Real-time clock on the Mega?
Many thanks in advance!
Kind regards,
Floris & Nico
It would be trivial for you to find out for yourself, but the answer is no.
If you don't want absolute accuracy then you could use the Arduino millis() function, one "tick" per millisecond, to provide the timing.
Yes you can create a new file each hour within the limit of the accuracy of the millis() function.
If you are planning only to write data to the file each hour then think very carefully about how it will be stored until written to the file as memory is limited on the Arduino.
UKHeliBob:
How would you program it if we'd say we'll use the millis() function? The file name is "datalog.txt" on the SD-card at the moment. So the name file should be "datalog1.txt", an hour later it would have to be "datalog2.txt".
This is our program atm:
String text;
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue0 = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float druk0 = (sensorValue0 * (5 / 1023.0) - 0.5) *(160/4);
//print out the value you read:
//Serial.println(druk0);
delay (0);
// read the input on analog pin 1:
int sensorValue1 = analogRead(A1);
float druk1 = (sensorValue1 * (5 / 1023.0) - 0.5) *(160/4);
// print out the value you read:
//Serial.println(druk1);
delay (0);
// read the input on analog pin 2:
int sensorValue2 = analogRead(A2);
float druk2 = (sensorValue2 * (5 / 1023.0) - 1) *(250/4);
//Serial.println(druk2);
delay (0);
// read the input on analog pin 3:
int sensorValue3 = analogRead(A3);
float druk3 = (sensorValue3 * (5 / 1023.0) - 1) *(250/4);
//Serial.println(druk3);
delay (0);
// read the input on analog pin 4:
int sensorValue4 = analogRead(A4);
float druk4 = (sensorValue4 * (5 / 1023.0) - 1) *(250/4);
//Serial.println(druk4);
delay (0);
// read the input on analog pin 5:
int sensorValue5 = analogRead(A5);
float druk5 = (sensorValue5 * (5 / 1023.0) - 1) *(250/4);
//Serial.println(druk5);
text = String(druk0)+ "\t"+String (druk1)+ "\t"+ String (druk2)+ "\t"+ String (druk3)+ "\t"+ String (druk4)+ "\t"+ String (druk5);
Serial.println(text);
delay (100);
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(text);
dataFile.close();
// print to the serial port too:
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
Something to get you started
char filename[13];
unsigned long startTime;
unsigned long currentTime;
//unsigned long oneHour = 1000UL * 60UL *60UL;
unsigned long oneHour = 2000UL;
int fileCount = 0;
  startTime = millis();
  currentTime = millis();
  if (currentTime - startTime >= oneHour)
    sprintf(filename, "data%03d.txt", fileCount);
    Serial.println(filename);
    fileCount++;
    startTime = currentTime;
You will see that I reduced the delay between generating filenames for testing.
I also changed the filename to keep it within the required 8.3 format
