Creating If Else Statement for Music Note Detection
I'm currently working on a project that detects music notes using different frequencies detected in the microphone. However, I am trying to add an If else statement that turns on 1 of 2 lights depending on the note that is played. I am very new to coding and have done nothing with arduino previously. If I can get some help or tips on coding this statement that would be greatly appreciated. I have used the code from Arduino Music: Notes and Chord Detector | Arduino Project Hub . I have got the microphone working and everything up and running and I am just trying to code the If else statement. I would like a green light to be turned on when the notes D (k==2), A (k==9), and B (k==11) Any help with coding and wiring is much appreciated. Thank you.
int  in[128];
byte NoteV[13]={8,23,40,57,76,96,116,138,162,187,213,241,255}; //data  for note detection based on frequency
float f_peaks[5]; // top 5 frequencies  peaks in descending order
int Mic_pin;
void  setup() {
Serial.begin(250000);
Mic_pin = A7;   // change as per Microphone  pin
  Tone_det();
//-----------------------------Tone  Detection Function----------------------------------------------//
// Documentation  on Tone_detection:https://www.instructables.com/member/abhilash_patel/instructables/
//  Code Written By: Abhilash Patel
// Contact: abhilashpatel121@gmail.com
//  This code written for arduino Nano board (should also work for UNO)
// This code  won't work for any board having RAM less than 2kb,
void Tone_det()
{  long unsigned int a1,b,a2;
  float a;
  float sum1=0,sum2=0;
  float sampling;
  a1=micros();
        for(int i=0;i<128;i++)
            a=analogRead(Mic_pin)-500;     //rough zero shift
            //utilising time between two sample for windowing  & amplitude calculation
            sum1=sum1+a;              //to average value
            sum2=sum2+a*a;            // to RMS value
            a=a*(sin(i*3.14/128)*sin(i*3.14/128));   // Hann window
            in[i]=10*a;                // scaling for float  to int conversion
            delayMicroseconds(195);   // based on operation  frequency range
b=micros();
sum1=sum1/128;               //  Average amplitude
sum2=sqrt(sum2/128);         // RMS
sampling= 128000000/(b-a1);  // real time sampling frequency
//for very low or no amplitude, this code  wont start
//it takes very small aplitude of sound to initiate for value sum2-sum1>3,
//change sum2-sum1 threshold based on requirement
if(sum2-sum1>3){
       FFT(128,sampling);
       //EasyFFT based optimised  FFT code,
       //this code updates f_peaks array with 5 most dominent frequency in descending  order
 for(int i=0;i<12;i++){in[i]=0;}  // utilising in[] array for further  calculation
int j=0,k=0; //below loop will convert frequency value to note
       for(int i=0; i<5;i++)
           if(f_peaks[i]>1040){f_peaks[i]=0;}
           if(f_peaks[i]>=65.4   && f_peaks[i]<=130.8) {f_peaks[i]=255*((f_peaks[i]/65.4)-1);}
           if(f_peaks[i]>=130.8  && f_peaks[i]<=261.6) {f_peaks[i]=255*((f_peaks[i]/130.8)-1);}
           if(f_peaks[i]>=261.6  && f_peaks[i]<=523.25){f_peaks[i]=255*((f_peaks[i]/261.6)-1);}
           if(f_peaks[i]>=523.25 && f_peaks[i]<=1046)  {f_peaks[i]=255*((f_peaks[i]/523.25)-1);}
           if(f_peaks[i]>=1046 && f_peaks[i]<=2093)  {f_peaks[i]=255*((f_peaks[i]/1046)-1);}
           if(f_peaks[i]>255){f_peaks[i]=254;}
           j=1;k=0;
         while(j==1)
              if(f_peaks[i]<NoteV[k]){f_peaks[i]=k;j=0;}
              k++;  // a note with max peaks (harmonic) with aplitude priority is  selected
              if(k>15){j=0;}
              if(f_peaks[i]==12){f_peaks[i]=0;}
              k=f_peaks[i];
              in[k]=in[k]+(5-i);
k=0;j=0;
              if(k<in[i]){k=in[i];j=i;}  //Max value detection
       // Note print
       // if  you need to use note value for some application, use of note number recomendded
       // where, 0=c;1=c#,2=D;3=D#;.. 11=B;
       //a2=micros(); // time  check
        k=j;
        if(k==0) {Serial.println('C');}
        if(k==1)  {Serial.print('C');Serial.println('#');}
        if(k==2) {Serial.println('D');}
        if(k==3) {Serial.print('D');Serial.println('#');}
        if(k==4) {Serial.println('E');}
        if(k==5) {Serial.println('F');}
        if(k==6) {Serial.print('F');Serial.println('#');}
        if(k==7) {Serial.println('G');}
        if(k==8) {Serial.print('G');Serial.println('#');}
        if(k==9) {Serial.println('A');}
        if(k==10){Serial.print('A');Serial.println('#');}
        if(k==11){Serial.println('B');}
//-----------------------------FFT  Function----------------------------------------------//
// Documentation on  EasyFFT:https://www.instructables.com/member/abhilash_patel/instructables/
//  EasyFFT code optimised for 128 sample size to reduce mamory consumtion
float  FFT(byte N,float Frequency)
byte data[8]={1,2,4,8,16,32,64,128};
int  a,c1,f,o,x;
a=N;
      for(int i=0;i<8;i++)                 //calculating the levels
         { if(data[i]<=a){o=i;} }
      o=7;
byte in_ps[data[o]]={};     //input for sequencing
float out_r[data[o]]={};   //real part of transform
float out_im[data[o]]={};  //imaginory part of transform
x=0;
      for(int b=0;b<o;b++)                     // bit reversal
          c1=data[b];
          f=data[o]/(c1+c1);
                for(int  j=0;j<c1;j++)
                     x=x+1;
                     in_ps[x]=in_ps[j]+f;
      for(int i=0;i<data[o];i++)            //  update input array as per bit reverse order
          if(in_ps[i]<a)
          {out_r[i]=in[in_ps[i]];}
          if(in_ps[i]>a)
          {out_r[i]=in[in_ps[i]-a];}
int i10,i11,n1;
float e,c,s,tr,ti;
    for(int  i=0;i<o;i++)                                    //fft
     i10=data[i];              // overall values of sine cosine
     i11=data[o]/data[i+1];    // loop with similar sine cosine
     e=6.283/data[i+1];
     e=0-e;
     n1=0;
          for(int j=0;j<i10;j++)
          c=cos(e*j);
          s=sin(e*j);
          n1=j;
                for(int  k=0;k<i11;k++)
                 tr=c*out_r[i10+n1]-s*out_im[i10+n1];
                 ti=s*out_r[i10+n1]+c*out_im[i10+n1];
                 out_r[n1+i10]=out_r[n1]-tr;
                 out_r[n1]=out_r[n1]+tr;
                 out_im[n1+i10]=out_im[n1]-ti;
                 out_im[n1]=out_im[n1]+ti;
                 n1=n1+i10+i10;
//---> here onward  out_r contains amplitude and our_in conntains frequency (Hz)
    for(int i=0;i<data[o-1];i++)               // getting amplitude from compex number
         out_r[i]=sqrt((out_r[i]*out_r[i])+(out_im[i]*out_im[i]));  // to  increase the speed delete sqrt
         out_im[i]=(i*Frequency)/data[o];
         Serial.print(out_im[i],2); Serial.print("Hz");
         Serial.print("\	");                            // uncomment to print freuency bin
         Serial.println(out_r[i]);
x=0;       // peak detection
   for(int i=1;i<data[o-1]-1;i++)
      if(out_r[i]>out_r[i-1] && out_r[i]>out_r[i+1])
      {in_ps[x]=i;    //in_ps array used for storage of peak number
      x=x+1;}
s=0;
c=0;
    for(int i=0;i<x;i++)             // re arraange as per magnitude
        for(int j=c;j<x;j++)
            if(out_r[in_ps[i]]<out_r[in_ps[j]])
                {s=in_ps[i];
                in_ps[i]=in_ps[j];
                in_ps[j]=s;}
    c=c+1;
    for(int i=0;i<5;i++)     // updating  f_peak array (global variable)with descending order
     f_peaks[i]=(out_im[in_ps[i]-1]*out_r[in_ps[i]-1]+out_im[in_ps[i]]*out_r[in_ps[i]]+out_im[in_ps[i]+1]*out_r[in_ps[i]+1])
     /(out_r[in_ps[i]-1]+out_r[in_ps[i]]+out_r[in_ps[i]+1]);
if (( k==2 ) "set led1")
else {
  reset led1;
  if((  k==9 ) "set led2")
  else {
    reset led2;
    if((  k==11 ) "set led3")
   reset led3;
I see in the setup function no pins are declared as outputs, therefore no pins can ever turn on any LEDs.
Note in that project it says:-
If we take the frequency transform of various musical instruments, it may contain multiple harmonics based on the note being played. Every instrument has its own signature combination of various harmonics.
It is more complex than that. On every real instrument and good synthesisers, the mixture of harmonics change over the duration of the note. Making this project just a simple hack. To actually cope with this you need much faster analysis and more complex search analysis than you can possibly do with an Arduino of any type.
Envelope. Understanding ADSR Envelopes (Sound Design Fundamentals)
It was not me that said that it was a quote from the project site.
There is much more to it than the ADSR, because that can be applied to a static waveform, and if so will not affect the harmonic component mix only the amplitudes of each FFT component. Which will defeat the simple fixed value recognition values used in this project.
But it is only a heuristic approach used here which is therefore not very good or very repeatable.
