Creating library help!
Dear reader,
To easy my programming I want to make a library that reads and ecoder en eventually send MIDI data over midi USB.
Since this is my first lib I want to make it step by step so errors are more easy to filter out and so I can understand how this proces works but even the first steps give me so much errors and I cannot find any solution more.
So to start this is the program i want to convert into a lib
#define pin_A 2 // interrupt 0
#define pin_B   4 // this can be any pin
volatile uint8_t encoder_counter;
volatile uint8_t encoder_pulse;
  pinMode(pin_A , INPUT);
  pinMode(pin_B , INPUT);
  attachInterrupt(digitalPinToInterrupt(pin_A), read_encoder, FALLING);
  if (encoder_pulse) {
    encoder_pulse = 0;
    Serial.print("encoder_counter: ");
    Serial.print(encoder_counter);
void read_encoder() {
    if (digitalRead(pin_B) == HIGH) // switch to LOW to reverse direction of Encoder counting
      encoder_counter++;
    else {
      encoder_counter--;
    encoder_pulse++;
so i made a .h file which looks like this:
  MIDI_encoder.h - Library for interfacing rotary encoders with software which communicate through MIDI.
  Created by Jazzy Gérard, February, 2017.
  Released into the public domain.
#ifndef MIDI_encoder_h
#define MIDI_encoder_h
#include "Arduino.h"
class MIDI_encoder
  public:
    MIDI_encoder(int pin_A, int pin_B);
    void read_encoder();
    volatile uint8_t encoder_counter = 127;
  private:
    int _pin_A;
    int _pin_B;
#endif
and a .cpp file which looks like this:
  MIDI_encoder.cpp - Library for interfacing rotary encoders with software which communicate through MIDI.
#include "MIDI_encoder.h"
MIDI_encoder::MIDI_encoder(int pin_A, int pin_B)
  pinMode(pin_A, INPUT);
  _pin_A = pin_A;
  pinMode(pin_B, INPUT);
  _pin_B = pin_B;
  attachInterrupt(digitalPinToInterrupt(_pin_A), read_encoder, FALLING);
void MIDI_encoder::read_encoder()
  if (digitalRead(_pin_B) == HIGH) // switch to LOW to reverse direction of Encoder counting
      encoder_counter++;
      encoder_counter--;
    encoder_pulse++;
So want I want to do in my first step is to make an instance which declares all inputs and the interrupt pin and work with the function "void read_encoder()"
I got already al lot of errors but the last one was the following:
Arduino: 1.8.0 (Mac OS X), TD: 1.34, Board:"Teensy 3.2 / 3.1, Serial, 96 MHz (overclock), Fast, US English"
/Users/Jazzy/Documents/Arduino/libraries/MIDI_encoder/MIDI_encoder.cpp: In constructor 'MIDI_encoder::MIDI_encoder(int, int)':
/Users/Jazzy/Documents/Arduino/libraries/MIDI_encoder/MIDI_encoder.cpp:16:71: error: cannot convert 'MIDI_encoder::read_encoder' from type 'void (MIDI_encoder::)()' to type 'void (*)()'
Fout bij het compileren van board Teensy 3.2 / 3.1
option enabled in File -> Preferences.
Can anyone please guide me through this proces!
thanks in advance!
Read_encoder is expected as a function. In a class, it's a method, so attachinterrupt can't find it. I believe you need to use a static method and object.
It's a bit tricky. Something like this
a.h
 static MIDI_encoder *thisClassObj; // get instance to call pointer
 static void get_encoder() {
     thisClassObj->read_endcoder();
a.cpp
MIDI_encoder *MIDI_encoder::thisClassObj // define this outside any method like on top of the page.
attachInterrupt(digitalPinToInterrupt(_pin_A), get_encoder, FALLING);
     thisClassObj
Thank you for the quick reply! what do you mean with thisClassObj?
Jazzy
It's a reference of class's instance in memory when you instantiate it.
It's not the most elegant thing in the world. You can see the limitation of C++ there.
Please use code tags also for warning or error methods.
mistergreen:
There is no such thing as a method in C++, in a class it's called a member function.
