void verticalMov() //pixel by pixel movement of a pixel:)
for (int y=19; y<29; y++) //starts in position 19, finishes in position 29
oled.clear(PAGE); //clears the displays buffer to erase previous pixels
oled.pixel(32,y); //buffers of pixel with fixed column in position 32
oled.display(); //prints pixel on display
delay(200); //delay, to control the movement speed
However in case of movement with an angle, I have to control two integers (x and y). And I can't do that by this code below, because nested FOR loop is counting first x and then y. I realize that the answer may be very simple, but I am not the programmer, just self teaching biologist:).
How to program such movements (both, horizontal and angled) with not just one pixel, but with set of couple pixels (like custom shape of i.e. 5 pixels).
This animation will be used to animate artificial prey in behavioral studies.
Thank you in advance for any help.
Not quite sure what you mean by angled movement but what you can do is this:
float x = 0;
float y = 0;
float dt = 0.01;
float moveN = 1; // You can change this to negative to move left or positive to move right
void Mov(){
x += moveN * dt;
y += moveN * dt;
I guess by angled you mean this:
float x = 0;
float y = 0;
float dt = 0.01;
float angle = 90;
void angledMove(){
x+= moveN * math.cos(angle) * dt;
y += moveN * math.sin(angle) * dt
You would need to execute the angledMove method in a loop.
In the case your OLED.pixel() function doesn't take in floats You have to cast them by doing this:
Thank you Bruce. By angle movement I meant other movements than horizontal and vertical (when both x and y coordinates are changed). I think that 45deg angle will be fine. I will check your ideas as soon as I get back to wires.
This seems to work for the Arduino IDE. You're best bet for representing Entities is to create a class. I'm aware that you don't know much about coding but I can help you.
OK, It works, I implemented it with a bit change, and the result looks like this:
There are 15 different paths in the animation, so the code got fatty.
But I still have no idea how to animate more complicated shapes on this pathway:(.
#include <Wire.h> // Include Wire if you're using I2C
#include <SPI.h> // Include SPI if you're using SPI
#include <SFE_MicroOLED.h> // Include the SFE_MicroOLED library
#define PIN_RESET 9 // Connect RST to pin 9 (req. for SPI and I2C)
#define PIN_DC 8 // Connect DC to pin 8 (required for SPI)
#define PIN_CS 10 // Connect CS to pin 10 (required for SPI)
#define DC_JUMPER 0
// Also connect pin 13 to SCK and pin 11 to MOSI
// MicroOLED Object Declaration //
// Declare a MicroOLED object. The parameters include:
// 1 - Reset pin: Any digital pin
// 2 - D/C pin: Any digital pin (SPI mode only)
// 3 - CS pin: Any digital pin (SPI mode only, 10 recommended)
MicroOLED oled(PIN_RESET, PIN_DC, PIN_CS);
//MicroOLED oled(PIN_RESET, DC_JUMPER); // Example I2C declaration
// I2C is great, but will result in a much slower update rate. The
// slower framerate may be a worthwhile tradeoff, if you need more
// pins, though.
// These three lines of code are all you need to initialize the
// OLED and print the splash screen.
// Before you can start using the OLED, call begin() to init
// all of the pins and configure the OLED.
oled.begin();
// clear(ALL) will clear out the OLED's graphic memory.
// clear(PAGE) will clear the Arduino's display buffer.
oled.clear(ALL); // Clear the display's memory (gets rid of artifacts)
// To actually draw anything on the display, you must call the
// display() function.
//oled.display();
float jumpSpeed = 200;
oled.invert(false);
oled.clear(PAGE);//clear the screen before we draw our image
VertUpCent();
Turn1();
HorizUpRight();
Turn2();
VertDownRight();
Turn3();
HorizDownRight();
Turn4();
VertUpCent();
Turn5();
HorizUpLeft();
Turn6();
VertDownLeft();
Turn7();
HorizDownLeft();
Turn8();
void VertUpCent() //vertical up center
float x1 = 32; //x start point
float y1 = 18; //y start point
float dt1 = 1; //distance
for (int n=1; n<12; n++)
//x1 += dt1;
y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void VertDownRight() //vertical down right
float x1 = 10; //x start point
float y1 = 30; //y start point
float dt1 = -1; // pos=up, neg=down
//x1 += dt1;
y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void VertDownLeft() //vertical down left
float x1 = 54; //x start point
float dt1 = -1; //distance
for (int n=1; n<12; n++) //number of steps
//x1 += dt1;
y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn1() // turn
for (int n=1; n<5; n++)
x1 -= dt1;
y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void HorizUpRight() //horizontal up right
float x1 = 27; //x start point
float y1 = 35; //y start point
float dt1 = 1; // pos=up, neg=down
x1 -= dt1;
//y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn2() // turn
float x1 = 15; //x start point
x1 -= dt1;
y1 -= dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn3() // turn
x1 += dt1;
y1 -= dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void HorizDownRight() //horizontal down right
float y1 = 13; //y start point
x1 += dt1;
//y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn4() // turn
x1 += dt1;
y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn5() // turn
x1 += dt1;
y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void HorizUpLeft() //horizontal up left
float x1 = 37; //x start point
x1 += dt1;
//y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn6() // turn
float x1 = 49; //x start point
x1 += dt1;
y1 -= dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn7() // turn
x1 -= dt1;
y1 -= dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void HorizDownLeft() //horizontal down left
x1 -= dt1;
//y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
void Turn8() // turn
x1 -= dt1;
y1 += dt1;
oled.clear(PAGE);
oled.pixel(x1,y1);
oled.display();
delay(jumpSpeed);
Floating-point calculations are relatively slow. If that's all that your Arduino is doing, then that's a good way to do it. If you need it to do other time-sensitive things simultaneously, then you may find that the FP calculations are the bottleneck.
One alternative for straight lines is called Bressenham's Algorithm. It is also relatively easy to make circles and ellipses but segments of circles and ellipses (like making a smooth turn between two straights) can get complex. Then you will probably end up back at the FP calculations again.
Hi guys,
indeed, making ellipses like these below is much more effortless in code than drawing single lines. I used shapes that were build into the display's library, and animated them along the pathway created with sin/cos function (and had to remind classes about trigonometry from 90ties:))). Thank you!
