Hello All,
I am using UIPEthernet library on enc28J60 on Arduino UNO. The code connecting a single server socket connection listening to single TCP client is working fine.
I wish to create 4 identical server objects listening to 4 identical clients - each with a different port number.
I wish to create an array of servers as follows:
EthernetServer server[0] = EthernetServer(port_num+0);
EthernetServer server[1] = EthernetServer(port_num+1);
EthernetServer server[2] = EthernetServer(port_num+2);
EthernetServer server[3] = EthernetServer(port_num+3);
When I compile this statement, I get an error as follows:
Tcp_Multi_Server_array.ino:48:24: error: conflicting declaration 'UIPServer server [1]'
Tcp_Multi_Server_array.ino:47:16: error: 'server' has a previous declaration as 'UIPServer server [0]'
It seems that library does not allow a subscripted variable as an object name. If yes then, is there a work around?
I wish I could do the instantiation of server inside a for loop in setup()!!
Thanks in advance.
