currently I am setting up a device to measure the brightness of a display and save the measured data to an SD card. Since I do not want a fixed name for the file but read it in via the serial monitor. I looked through a lot of threads here but cannot solve it anyhow. As far as I understood the String from serial read must be converted to a string but the .c_str() is not working. Can anybody help me here ?
#include <SPI.h>
#include <SD.h>
const int CSmemory = 9; //Chip select for SD card module
const int aInput1 = A0;
const int aInput2 = A1;
const int aInput3 = A2;
String cali = "";
String measname = "";
pinMode(CSmemory, OUTPUT);
pinMode(aInput1, INPUT);
pinMode(aInput2, INPUT);
pinMode(aInput3, INPUT);
int ADCread1 = 0;
int zw = 0;
int topvalue = 0;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(CSmemory)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
SPI.begin();
Serial.print("Name of measurment?"); //here starts the naming process
while (Serial.available() == 0) {}
measname = Serial.readString();
Serial.print("I received ");
Serial.println(measname);
File dataFile = SD.open(measname.c_str(), FILE_WRITE);
if (dataFile) {
do{
ADCread1 = analogRead(aInput1);
}while (ADCread1 <40);
for (int i = 0; i < 256; i++) {
dataFile.println(ADCread1);
if (i==255){
topvalue = ADCread1;
dataFile.flush();
Serial.print("Finish rise measurment");
if (dataFile) {
do{
}while (ADCread1 >= topvalue-15);
dataFile.println(ADCread1); }
dataFile.close();
Serial.print("Finish complete measurment");
Well normally after the file creation the measurement starts as soon as there is a brightness change. This is not happening when I am not using something like "test.txt" instead of the variable. So it might be that the command itself is working but no file is created
In your sketch that uses Strings what do you see when you print the filename after conversion from a String to a C style string ? Before you print it. print a ">" and after you print it using Serial.print() (not Serial.println()) print a "<". This will allow you to see whether there are hidden control characters such as Carriage Return and/or Linefeed as part of teh C string
It will be used as a C style constant string (lowercase s) but my point was that when you do
I am not convinced that the value of measname is what you think. For instance, try this
while (!Serial);
Serial.print(">");
Serial.print(measname);
Serial.print("<");
If you have the Line ending of the Serial monitor set to anything but No line ending then the output will be like this if you enter filename
I received >filename
Noye that the < is on a new line, which means that the String has an extra control character (or 2) on the end so no wonder you can't use it as a filename
Ah now I understood. I tried it as you said and unfortunately I cannot copy the serial monitor, but I have a new line after the name. so it seems that there are some extra control character(s?). How can I get rid of it ?
When debugging do not take anything for granted. For instance, if and while tests may fail to do what you expect so it is helpful to print the values of what is being tested and in the case of your sketch if you had put an else on the if (dataFile) then you might had got an inkling that something was wrong in that area
The trick of adding start and end markers when printing Strings or strings is also something to consider doing so that you can see whether there are non printing characters at the start and end
