Creating Wi-Fi code that will work on NodeMCU and Mega
So I have a project that uses a Wi-Fi master to send LED value to Wi-Fi slaves, this works well on NodeMCU boards.
I now need to port the master to a Mega as I need 2 serial ports, one for the Wi-Fi (ESP-01) on the Mega and one for adding DMX receiving. I have a ESP-01 board and a ESP8266 module.
I would like to be able to use the same code, if possible, with only pin adjustments between the differnet devices I flash it to.
Is there a way to configure a ESP-01 on a Mega so the same code can be used as I use on the NodeMCU’s?
Here’s the code I use on the NodeMCU’s.
Thanks in advance for ideas and suggestions as this is a very steep learning curve for me.
#include <FastLED.h>
#include <ESP8266WiFi.h>
#include <WiFiUDP.h>
#include "reactive_common.h"
#define READ_PIN 0
#define BUTTON_PIN D1
#define NUMBER_OF_CLIENTS 1
const int checkDelay = 5000;
const int buttonDoubleTapDelay = 200;
const int numOpModes = 3;
unsigned long lastChecked;
unsigned long buttonChecked;
bool buttonClicked = false;
bool queueDouble = false;
bool clickTrigger;
bool doubleTapped;
WiFiUDP UDP;
struct led_command {
  uint8_t opmode;
  uint32_t data;
bool heartbeats[NUMBER_OF_CLIENTS];
static int opMode = 1;
  pinMode(READ_PIN, INPUT);
  pinMode(BUTTON_PIN, INPUT );
  /* WiFi Part */
  Serial.print("Setting soft-AP ... ");
  WiFi.persistent(false);
  WiFi.mode(WIFI_AP);
  WiFi.softAP("sound_reactive", "123456789");
  Serial.print("Soft-AP IP address = ");
  Serial.println(WiFi.softAPIP());
  UDP.begin(7171);
  resetHeartBeats();
  waitForConnections();
  lastChecked = millis();
  buttonChecked = 0;
  uint32_t analogRaw;
  buttonCheck();
  if (millis() - lastChecked > checkDelay) {
    if (!checkHeartBeats()) {
  switch (opMode) {
    case 1:
      analogRaw = analogRead(READ_PIN);
      if (analogRaw <= 3)
      sendLedData(analogRaw, opMode);
    case 2:
      sendLedData(0, opMode);
      delay(10);
    case 3:
      delay(10);
  delay(4);
void sendLedData(uint32_t data, uint8_t op_mode)
 struct led_command send_data;
 send_data.opmode = op_mode;
 send_data.data = data;
 for (int i = 0; i < NUMBER_OF_CLIENTS; i++)
    IPAddress ip(192,168,4,2 + i);
    UDP.beginPacket(ip, 7001);
    UDP.write((char*)&send_data,sizeof(struct led_command));
    UDP.endPacket();
void waitForConnections() {
  while(true) {
      readHeartBeat();
      if (checkHeartBeats()) {
        return;
      delay(checkDelay);
      resetHeartBeats();
void resetHeartBeats() {
  for (int i = 0; i < NUMBER_OF_CLIENTS; i++) {
   heartbeats[i] = false;
void readHeartBeat() {
  struct heartbeat_message hbm;
 while(true) {
  int packetSize = UDP.parsePacket();
  if (!packetSize) {
  UDP.read((char *)&hbm, sizeof(struct heartbeat_message));
  if (hbm.client_id > NUMBER_OF_CLIENTS) {
    Serial.println("Error: invalid client_id received");
    continue;
  heartbeats[hbm.client_id - 1] = true;
bool checkHeartBeats() {
   if (!heartbeats[i]) {
    return false;
  resetHeartBeats();
  return true;
void buttonCheck()
  int but = digitalRead(BUTTON_PIN);
  if (but == 0) {
    if (millis() - buttonChecked < buttonDoubleTapDelay && buttonClicked == false ) {
      doubleClicked();
      doubleTapped = true;
    clickTrigger = true;
    buttonClicked = true;
    buttonChecked = millis();
  else if (but == 1) {
    if (millis() - buttonChecked > buttonDoubleTapDelay && clickTrigger) {
      if (!doubleTapped) {
        clicked();
      clickTrigger = false;
      doubleTapped = false;
void clicked() {
  if (opMode == numOpModes)
    opMode = 1;
    opMode++;
  Serial.printf("Setting opmode %d \n", opMode);
void doubleClicked() {
you could try my WiFiEspAT library in Mega with AT firmware in esp8266. https://github.com/jandrassy/WiFiEspAT
I already have a program that works on a NodeMCU, please see below.
Would it be straightforward to change the Wi-Fi library I am using to yours?
#define READ_PIN 0
bool clickTrigger;
bool doubleTapped;
WiFiUDP UDP;
  uint8_t opmode;
  uint32_t data;
  /* WiFi Part */
  WiFi.mode(WIFI_AP);
  UDP.begin(7171);
  resetHeartBeats();
  buttonChecked = 0;
  uint32_t analogRaw;
  buttonCheck();
  switch (opMode) {
    case 1:
      if (analogRaw <= 3)
    case 2:
      delay(10);
    case 3:
      delay(10);
  delay(4);
    UDP.endPacket();
  while(true) {
      readHeartBeat();
        return;
      delay(checkDelay);
      resetHeartBeats();
 while(true) {
  if (!packetSize) {
    continue;
    return false;
  resetHeartBeats();
  return true;
void buttonCheck()
  if (but == 0) {
      doubleClicked();
        clicked();
void clicked() {
    opMode = 1;
    opMode++;
Blue407:
#include “reactive_common.h”
#define READ_PIN 0
bool clickTrigger;
bool doubleTapped;
WiFiUDP UDP;
  uint8_t opmode;
  uint32_t data;
/* WiFi Part */
  Serial.print("Setting soft-AP … ");
  WiFi.mode(WIFI_AP);
  WiFi.softAP(“sound_reactive”, “123456789”);
  UDP.begin(7171);
  resetHeartBeats();
  buttonChecked = 0;
  uint32_t analogRaw;
  buttonCheck();
switch (opMode) {
    case 1:
      if (analogRaw <= 3)
    case 2:
      delay(10);
    case 3:
      delay(10);
  delay(4);
    UDP.endPacket();
  while(true) {
      readHeartBeat();
        return;
      delay(checkDelay);
      resetHeartBeats();
while(true) {
  if (!packetSize) {
    Serial.println(“Error: invalid client_id received”);
    continue;
    return false;
  resetHeartBeats();
  return true;
void buttonCheck()
  if (but == 0) {
      doubleClicked();
        clicked();
void clicked() {
    opMode = 1;
    opMode++;
  Serial.printf(“Setting opmode %d \n”, opMode);
besides the include, you will have to change
WiFi.beginAP(“sound_reactive”, “123456789”);
Serial.println(WiFi.apIP());
I will take a look then, thank you :)
