Bonjour à tous,
Je me lance dans la création d'un joystick pour jouer à SWTOR : Galactic Starfighter avec un LEONARDO.
Ce jeu est prévu pour être joué à la souris et au clavier.
Code actuel (mouvement du manche + les boutons) édit du 17/01/2016
// Clavier Matrix 4x4
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{'1','2','3','4'},
{'5','6','7','8'},
{'9','a','b','c'},
{'d','e','f','g'}
byte rowPins[ROWS] = {7, 6, 5, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {3, 2, 1, 0}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// Axes X et Y
const int xAxis = A0;
const int yAxis = A1;
//const int bouton = A5;
int responseDelay = 2;
int axis[] = { xAxis, yAxis};
int curseur_position[] = {0, 0};
int calibrage[] = {0, 0};
int check[] = {0, 0};
int coef = 3;
Mouse.begin();
// Serial.begin(9600);
// Les 5 boutons sur le manche
if (digitalRead(8) == HIGH) {
Mouse.press();
else {
Mouse.release();
if (digitalRead(9) == HIGH) {
Mouse.press(MOUSE_RIGHT);
else {
Mouse.release(MOUSE_RIGHT);
if (digitalRead(10) == HIGH) {
Keyboard.press(KEY_BACKSPACE);
Keyboard.releaseAll();
delay(50);
if (digitalRead(11) == HIGH) {
Keyboard.press('v');
delay(50);
// Matrix 4x4
char key = keypad.getKey();
if (key != NO_KEY){
if (key == '1') {
centrage();
else if (key == '2') {
Keyboard.press(KEY_TAB);
else if (key == '3') {
Keyboard.press('8');
else if (key == '4') {
Keyboard.press('2');
else if (key == '5') {
Keyboard.press('r');
else if (key == '6') {
Keyboard.press('4');
else if (key == '7') {
Keyboard.press('5');
else if (key == '8') {
Keyboard.press('6');
else if (key == '9') {
Keyboard.press(KEY_F1);
else if (key == 'a') {
Keyboard.press(KEY_F2);
else if (key == 'b') {
Keyboard.press(KEY_F3);
else if (key == 'c') {
Keyboard.press(KEY_F4);
else if (key == 'd') {
Keyboard.press('&');
else if (key == 'e') {
Keyboard.press('\'');
else if (key == 'f') {
Keyboard.press('(');
else if (key == 'g') {
Keyboard.press('-');
// mouvements de la souris
int xReading = readAxis(0);
int yReading = readAxis(1);
Mouse.move(xReading, yReading, 0);
delay(responseDelay);
// Les fonctions
int readAxis(int axisNumber) {
if (check[axisNumber] == 0) {
calibrage[axisNumber] = 517 - analogRead(axis[axisNumber]);
check[axisNumber] = 1;
int distance = 0;
int reading = (analogRead(axis[axisNumber]) + calibrage[axisNumber]) * coef;
if (reading > (519 * coef + curseur_position[axisNumber])) {
distance = 5;
else if (reading > (515 * coef + curseur_position[axisNumber])) {
distance = 0;
else if (reading > (404 * coef + curseur_position[axisNumber])) {
distance = -5;
// correction des erreurs du retour au centre du manche
// pas de correction pour les valeur 5 et -5, ca évite de donner la bougeotte au curseur ;)
if (reading >= 1540 && reading <= 1570 && abs(curseur_position[axisNumber]) > 5) {
distance = - curseur_position[axisNumber];
curseur_position[axisNumber] = 0;
else {
// les coordonnées 0,0 sont tjs la dernière possition
curseur_position[axisNumber] = distance + curseur_position[axisNumber];
// inverse le sens de y
// if (axisNumber == 1) {
// distance = -distance;
return distance;
// fonction de centrage du curseur (683, 384) ecran 1366, 768
int centrage() {
// Val max pour Mouse.move() vive les variables char....
int x = 127;
int y = 127;
for (int i=0; i<10; i++) {
Mouse.move(x, y, 0);
for (int i=0; i<5; i++) {
Mouse.move(-x, 0, 0);
Mouse.move(-48, 0, 0);
for (int i=0; i<3; i++) {
Mouse.move(0, -y, 0);
Mouse.move(0, -3, 0);
Post d'origine :
Titre : Leonardo sensibilité du curseur souris commandé par un joystick.
Bonjour à tous,
Je cherche a faire un joystick pour un jeu qui se joue à la souris et au clavier.
Pour le moment, je teste avec un petite joystick comme celui là :
Par la suite avec ça :
Je teste avec le code d'exemple (Mouse.move() - Arduino Reference) que j'ai tenté de modifier sans succès...
J'aimerai exploité des valeurs avec décimales pour avoir plus grande précision car avec le code d’origine je n'ai que des entiers.Code après mes modifs qui n'ont rien changé
const int xAxis = A3; //analog sensor for X axis
const int yAxis = A4; // analog sensor for Y axis
float range = 12; // output range of X or Y movement
float responseDelay = 2; // response delay of the mouse, in ms
//int threshold = range/4; // resting threshold
float threshold = range/10000;
float center = range/2; // resting position value
int minima[] = { 0, 0}; // actual analogRead minima for {x, y}
int maxima[] = { 1023, 1023}; // actual analogRead maxima for {x, y}
int axis[] = { xAxis, yAxis}; // pin numbers for {x, y}
float mouseReading[2]; // final mouse readings for {x, y}
Mouse.begin();
// read and scale the two axes:
float xReading = readAxis(0);
float yReading = readAxis(1);
// move the mouse:
Serial.print("x : ");
Serial.print(xReading);
Serial.print(" y : ");
Serial.println(yReading);
reads an axis (0 or 1 for x or y) and scales the
analog input range to a range from 0 to
float readAxis(int axisNumber) {
float distance = 0; // distance from center of the output range
// read the analog input:
float reading = analogRead(axis[axisNumber]);
// of the current reading exceeds the max or min for this axis,
// reset the max or min:
if (reading < minima[axisNumber]) {
minima[axisNumber] = reading;
if (reading > maxima[axisNumber]) {
maxima[axisNumber] = reading;
// map the reading from the analog input range to the output range:
reading = map(reading, minima[axisNumber], maxima[axisNumber], 0, range);
// if the output reading is outside from the
// rest position threshold, use it:
if (abs(reading - center) > threshold) {
distance = (reading - center);
// the Y axis needs to be inverted in order to
// map the movemment correctly:
// return the distance for this axis:
return distance;
Merci par avance pour votre aide. Amicalement Jyp
