Obbiettivo:
creare e connettersi ad un web server attraverso arduino e arduino GSM shield 2
Codice:
File/esempi/GSM/GsmWebServer
Descrizione:
1- Collegato e testato il funzionamento di arduino, shield, sim caricando l'esempio: File/esempi/GSM/ReceivesSMS, tutto funziona alla perfezione.
2- ora ho modificato lo sketch di GsmWebServer, applicando i dati relativi alla sim del mio provider che ho recuperato da internet
GSM Web Server
A simple web server that shows the value of the analog input pins.
using a GSM shield.
Circuit:
* GSM shield attached
* Analog inputs attached to pins A0 through A5 (optional)
created 8 Mar 2012
by Tom Igoe
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// APN data
#define GPRS_APN "mobile.vodafone.it" // replace your GPRS APN
#define GPRS_LOGIN "" // replace with your GPRS login
#define GPRS_PASSWORD "" // replace with your GPRS password
// initialize the library instance
GPRS gprs;
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSMServer server(80); // port 80 (http default)
// timeout
const unsigned long __TIMEOUT__ = 10*1000;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if((gsmAccess.begin(PINNUMBER)==GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY))
notConnected = false;
Serial.println("Not connected");
Serial.println("Connected to GPRS network");
// start server
server.begin();
//Get IP.
IPAddress LocalIP = gprs.getIPAddress();
Serial.println("Server IP address=");
Serial.println(LocalIP);
// listen for incoming clients
GSMClient client = server.available();
if (client)
while (client.connected())
if (client.available())
Serial.println("Receiving request!");
bool sendResponse = false;
while(char c=client.read()) {
if (c == '\n') sendResponse = true;
// if you've gotten to the end of the line (received a newline
// character)
if (sendResponse)
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(analogRead(analogChannel));
client.println("
client.println("</html>");
//necessary delay
client.stop();
3- Caricato lo sketch ed aperto il serial monitor ottengo:
Server IP address=
10.40.14.123
Problema:
Apro firefox dal mio pc connesso ad internet ed inserisco l'IP ma non riesco a connettermi. Qualcuno sa aiutarmi?
Grazie
