Creer un serveur affichant sur une carte des donné gps avec arduino uno wifi r2
bonjour,
Je voudrais créer une carte en ligne affichant les donné de mon capteur gps .
j'ai essayé ce code :
#include "defines.h"
#define WIFI_FIRMWARE_LATEST_VERSION        "1.4.8"
#include <SPI.h>
#include <WiFiNINA_Generic.h>
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;        // your network password (use for WPA, or use as key for WEP), length must be 8+
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  //Initialize serial and wait for port to open:
  while (!Serial && millis() < 5000);
  Serial.print(F("\nStart WiFiWebServer on ")); Serial.println(BOARD_NAME);
  Serial.println(WIFININA_GENERIC_VERSION);
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE)
    Serial.println(F("Communication with WiFi module failed!"));
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION)
    Serial.print(F("Your current firmware NINA FW v"));
    Serial.println(fv);
    Serial.print(F("Please upgrade the firmware to NINA FW v"));
    Serial.println(WIFI_FIRMWARE_LATEST_VERSION);
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED)
    Serial.print(F("Attempting to connect to SSID: "));
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    //delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWiFiStatus();
  // listen for incoming clients
  WiFiClient client = server.available();
  if (client)
    Serial.println(F("New client"));
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected())
      if (client.available())
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank)
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
            client.println("var centerpos = new google.maps.LatLng(48.579400,7.7519);");
            client.println("var optionsGmaps = {");
            client.println("   center:centerpos,");
            client.println("mapTypeId: google.maps.MapTypeId.ROADMAP,");
            client.println(" zoom: 15");
            client.println("};");
            client.println("var map = new google.maps.Map(document.getElementById(\"map\"), optionsGmaps");
          // output the value of each analog input pin
           client.println("var latlng;");
          client.println("</html>");
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println(F("Client disconnected"));
void printWiFiStatus()
  // print the SSID of the network you're attached to:
  Serial.print(F("SSID: "));
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print(F("IP Address: "));
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print(F("Signal strength (RSSI):"));
  Serial.print(rssi);
  Serial.println(F(" dBm"));
mais le serveur affiche juste le code :
demandé au lieu de l'executer.
existe il d'autre moyen de faire cette carte en ligne?( je rajouterai mes coordonné gps apres)
merci d'avance .
regardez le HTML généré
<!DOCTYPE HTML>
<html>
   center:centerpos,
 zoom: 15
var map = new google.maps.Map(document.getElementById("map"), optionsGmaps
var latlng;
</html>
ce n'est absolument pas suffisant pour afficher une carte....et la partie javascript devrait sans doute se trouver entre balises de script de toutes façons...
J'ai trouvé ce code :
<style>.embed-container {position: relative; padding-bottom: 80%; height: 0; max-width: 100%;} .embed-container iframe, .embed-container object, .embed-container iframe{position: absolute; top: 0; left: 0; width: 100%; height: 100%;} small{position: absolute; z-index: 100; bottom: 0; margin-bottom: -15px;}</style><div class=\"embed-container\"><iframe width=\"500\" height=\"400\" frameborder=\"0\" scrolling=\"no\" marginheight=\"0\" marginwidth=\"0\" title=\"arduino2\" src=\"//www.arcgis.com/apps/Embed/index.html?webmap=82e205ded0944c43aa92446d6339cc76&extent=-14.0184,39.8074,18.4352,52.3344&zoom=true&previewImage=false&scale=true&disable_scroll=true&theme=light\"></iframe></div>
comment pourais-je le modifier pour centrer sur une position ?
(le code marche parfaitement : il affiche la carte.
regardez les google API pour maps
Ce code marche,il faut juste le resentrer, je pensse qu'une de ces valeur doit indiquer le centre (le code est fait avec l'API ARCgis
S'il y a une API, il doit bien y avoir une doc, j'imagine.
effectivement, la doc est mal faite mais elle est la, mon serveur est desormais operationel!
Bonjour @enfant_meme ,
Je suis intéressé, vous pouvez poster la totalité de votre code, la dernière version qui fonctionne ?
Merci par avance.
je vous l'envoye des que je l'ai parfaitement fini: il n'est pas assez precis
voici le code, il n'est pas tres preci mais il marche
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
#include <SPI.h>
int vitesse = 0;
double distancemaison =0;
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPSPlus object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// For stats that happen every 5 seconds
unsigned long last = 0UL;
 int long lat = 0.0000000;
  int long   longi= 0.0000000;
   ss.begin(GPSBaud);
    // don't continue
    while (true);
    Serial.println(fv);
    //delay(10000);
  server.begin();
  printWiFiStatus();
    while (ss.available() > 0)
    gps.encode(ss.read());
  if (gps.location.isUpdated())
  lat = gps.location.lat()*10000000;
 longi = gps.location.lng()*10000000;
   Serial.print(F("  Lat="));
    Serial.print(lat,7);
    Serial.print(F(" Long="));
    Serial.println(longi,7);
  else if (gps.satellites.isUpdated())
    Serial.print(F("SATELLITES Fix Age="));
    Serial.print(gps.satellites.age());
    Serial.print(F("ms Value="));
    Serial.println(gps.satellites.value());
 if (gps.location.isValid())
      static const double Maison_LAT = , Maison_LON =;
     distancemaison =
        TinyGPSPlus::distanceBetween(
          gps.location.lat(),
          gps.location.lng(),
          Maison_LAT,
          Maison_LON);}
  if (client)
        Serial.write(c);
  client.println("<head>");
client.println(" <meta charset=\"utf-8\">");
 client.println(" <meta name=\"viewport\" content=\"initial-scale=1, maximum-scale=1, user-scalable=no\">");
  client.println("<title>Map arduino wifi </title>");
 client.println(" <style>");
   client.println(" html, body, #viewDiv {");
    client.println("  padding: 0;");
    client.println("  margin: 0;");
    client.println("  height: 100%;");
    client.println("  width: 100%;");
   client.println(" }");
 client.println(" </style>");
  client.println("<link rel=\"stylesheet\" href=\"https://js.arcgis.com/4.24/esri/themes/light/main.css\">");
  client.println("<script src=\"https://js.arcgis.com/4.24/\"></script>");
 client.println(" <script>");
 client.println(" require([");
  client.println("  \"esri/config\",");
  client.println("  \"esri/Map\",");
  client.println("  \"esri/views/MapView\",");
   client.println(" \"esri/Graphic\",");
   client.println("\"esri/layers/GraphicsLayer\"");
   client.println(" ], function(esriConfig,Map, MapView, Graphic, GraphicsLayer) {");
  client.println("esriConfig.apiKey = \"votre api arcgis\";");
 client.println("const map = new Map({");
  client.println("  basemap: \"arcgis-topographic\" //Basemap layer service");
 client.println(" });");
 client.println(" const view = new MapView({");
  client.println("  map: map,");
 client.print("   center: [");client.print(longi/10000000);client.print(",");client.print(lat/10000000);client.println("],");
  client.println("  zoom: 30,");
  client.println("  container: \"viewDiv\"");
 client.println("});");
client.println(" const graphicsLayer = new GraphicsLayer();");
client.println(" map.add(graphicsLayer);");
 client.println("const point = { //Create a point");
 client.println("   type: \"point\",");
  client.print("  longitude: ");client.print(gps.location.lng());client.println(",");
  client.println("  latitude: ");client.println(gps.location.lat());
client.println(" const simpleMarkerSymbol = {");
   client.println(" type: \"simple-marker\",");
  client.println("  color: [226, 119, 40],  // Orange");
  client.println("  outline: {");
    client.println("    color: [255, 255, 255], // White");
    client.println("    width: 1");
 client.println("const pointGraphic = new Graphic({");
 client.println("   geometry: point,");
  client.println("  symbol: simpleMarkerSymbol");
client.println(" graphicsLayer.add(pointGraphic);");
client.println("</script>");
client.println("</head>");
client.println("<body>");
 client.println(" <div id=\"viewDiv\"></div>");
client.println("</body>");
    client.stop();
  Serial.println(ip);
  Serial.print(rssi);
onglet define
#ifndef defines_h
#define defines_h
#if   ( defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_MKRWIFI1010) \
      || defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_SAMD_MKRFox1200) || defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) \
      || defined(ARDUINO_SAMD_MKRGSM1400) || defined(ARDUINO_SAMD_MKRNB1500) || defined(ARDUINO_SAMD_MKRVIDOR4000) \
      || defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS) || defined(__SAMD51__) || defined(__SAMD51J20A__) \
      || defined(__SAMD51J19A__) || defined(__SAMD51G19A__) || defined(__SAMD51P19A__)  \
      || defined(__SAMD21E15A__) || defined(__SAMD21E16A__) || defined(__SAMD21E17A__) || defined(__SAMD21E18A__) \
      || defined(__SAMD21G15A__) || defined(__SAMD21G16A__) || defined(__SAMD21G17A__) || defined(__SAMD21G18A__) \
      || defined(__SAMD21J15A__) || defined(__SAMD21J16A__) || defined(__SAMD21J17A__) || defined(__SAMD21J18A__) )
  #if defined(WIFININA_USE_SAMD)
    #undef WIFININA_USE_SAMD
  #endif
  #define WIFININA_USE_SAMD      true
#endif
  #if defined(ARDUINO_SAMD_ZERO)
    #define BOARD_TYPE      "SAMD Zero"
  #elif defined(ARDUINO_SAMD_MKR1000)
    #define BOARD_TYPE      "SAMD MKR1000"
  #elif defined(ARDUINO_SAMD_MKRWIFI1010)
    #define BOARD_TYPE      "SAMD MKRWIFI1010"
  #elif defined(ARDUINO_SAMD_NANO_33_IOT)
    #define BOARD_TYPE      "SAMD NANO_33_IOT"
  #elif defined(ARDUINO_SAMD_MKRFox1200)
    #define BOARD_TYPE      "SAMD MKRFox1200"
  #elif ( defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) )
    #define BOARD_TYPE      "SAMD MKRWAN13X0"
  #elif defined(ARDUINO_SAMD_MKRGSM1400)
    #define BOARD_TYPE      "SAMD MKRGSM1400"
  #elif defined(ARDUINO_SAMD_MKRNB1500)
    #define BOARD_TYPE      "SAMD MKRNB1500"
  #elif defined(ARDUINO_SAMD_MKRVIDOR4000)
    #define BOARD_TYPE      "SAMD MKRVIDOR4000"
  #elif defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
    #define BOARD_TYPE      "SAMD ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS"
  #elif defined(ADAFRUIT_FEATHER_M0_EXPRESS)
    #define BOARD_TYPE      "SAMD21 ADAFRUIT_FEATHER_M0_EXPRESS"
  #elif defined(ADAFRUIT_METRO_M0_EXPRESS)
    #define BOARD_TYPE      "SAMD21 ADAFRUIT_METRO_M0_EXPRESS"
  #elif defined(ADAFRUIT_CIRCUITPLAYGROUND_M0)
    #define BOARD_TYPE      "SAMD21 ADAFRUIT_CIRCUITPLAYGROUND_M0"
  #elif defined(ADAFRUIT_GEMMA_M0)
    #define BOARD_TYPE      "SAMD21 ADAFRUIT_GEMMA_M0"
  #elif defined(ADAFRUIT_TRINKET_M0)
    #define BOARD_TYPE      "SAMD21 ADAFRUIT_TRINKET_M0"
  #elif defined(ADAFRUIT_ITSYBITSY_M0)
    #define BOARD_TYPE      "SAMD21 ADAFRUIT_ITSYBITSY_M0"
  #elif defined(ARDUINO_SAMD_HALLOWING_M0)
    #define BOARD_TYPE      "SAMD21 ARDUINO_SAMD_HALLOWING_M0"
  #elif defined(ADAFRUIT_METRO_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_METRO_M4_EXPRESS"
  #elif defined(ADAFRUIT_GRAND_CENTRAL_M4)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_GRAND_CENTRAL_M4"
  #elif defined(ADAFRUIT_FEATHER_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_FEATHER_M4_EXPRESS"
  #elif defined(ADAFRUIT_ITSYBITSY_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_ITSYBITSY_M4_EXPRESS"
  #elif defined(ADAFRUIT_TRELLIS_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_TRELLIS_M4_EXPRESS"
  #elif defined(ADAFRUIT_PYPORTAL)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_PYPORTAL"
  #elif defined(ADAFRUIT_PYPORTAL_M4_TITANO)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_PYPORTAL_M4_TITANO"
  #elif defined(ADAFRUIT_PYBADGE_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_PYBADGE_M4_EXPRESS"
  #elif defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_METRO_M4_AIRLIFT_LITE"
  #elif defined(ADAFRUIT_PYGAMER_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_PYGAMER_M4_EXPRESS"
  #elif defined(ADAFRUIT_PYGAMER_ADVANCE_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_PYGAMER_ADVANCE_M4_EXPRESS"
  #elif defined(ADAFRUIT_PYBADGE_AIRLIFT_M4)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_PYBADGE_AIRLIFT_M4"
  #elif defined(ADAFRUIT_MONSTER_M4SK_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_MONSTER_M4SK_EXPRESS"
  #elif defined(ADAFRUIT_HALLOWING_M4_EXPRESS)
    #define BOARD_TYPE      "SAMD51 ADAFRUIT_HALLOWING_M4_EXPRESS"
  #elif defined(SEEED_WIO_TERMINAL)
    #define BOARD_TYPE      "SAMD SEEED_WIO_TERMINAL"
  #elif defined(SEEED_FEMTO_M0)
    #define BOARD_TYPE      "SAMD SEEED_FEMTO_M0"
  #elif defined(SEEED_XIAO_M0)
    #define BOARD_TYPE      "SAMD SEEED_XIAO_M0"
  #elif defined(Wio_Lite_MG126)
    #define BOARD_TYPE      "SAMD SEEED Wio_Lite_MG126"
  #elif defined(WIO_GPS_BOARD)
    #define BOARD_TYPE      "SAMD SEEED WIO_GPS_BOARD"
  #elif defined(SEEEDUINO_ZERO)
    #define BOARD_TYPE      "SAMD SEEEDUINO_ZERO"
  #elif defined(SEEEDUINO_LORAWAN)
    #define BOARD_TYPE      "SAMD SEEEDUINO_LORAWAN"
  #elif defined(SEEED_GROVE_UI_WIRELESS)
    #define BOARD_TYPE      "SAMD SEEED_GROVE_UI_WIRELESS"
  #elif defined(__SAMD21E18A__)
    #define BOARD_TYPE      "SAMD21E18A"
  #elif defined(__SAMD21G18A__)
    #define BOARD_TYPE      "SAMD21G18A"
  #elif defined(__SAMD51G19A__)
    #define BOARD_TYPE      "SAMD51G19A"
  #elif defined(__SAMD51J19A__)
    #define BOARD_TYPE      "SAMD51J19A"
  #elif defined(__SAMD51P19A__)
    #define BOARD_TYPE      "__SAMD51P19A__"
  #elif defined(__SAMD51J20A__)
    #define BOARD_TYPE      "SAMD51J20A"
  #elif defined(__SAM3X8E__)
    #define BOARD_TYPE      "SAM3X8E"
  #elif defined(__CPU_ARC__)
    #define BOARD_TYPE      "CPU_ARC"
  #elif defined(__SAMD51__)
    #define BOARD_TYPE      "SAMD51"
  #else
    #define BOARD_TYPE      "SAMD Unknown"
  #endif
#endif
#if ( defined(NRF52840_FEATHER) || defined(NRF52832_FEATHER) || defined(NRF52_SERIES) || defined(ARDUINO_NRF52_ADAFRUIT) || \
      defined(NRF52840_FEATHER_SENSE) || defined(NRF52840_ITSYBITSY) || defined(NRF52840_CIRCUITPLAY) || defined(NRF52840_CLUE) || \
      defined(NRF52840_METRO) || defined(NRF52840_PCA10056) || defined(PARTICLE_XENON) || defined(NINA_B302_ublox) || defined(NINA_B112_ublox) )
  #if defined(WIFININA_USE_NRF52)
    #undef WIFININA_USE_NRF52
  #endif
  #define WIFININA_USE_NRF52     true
#endif
  #if defined(NRF52840_FEATHER)
    #define BOARD_TYPE      "NRF52840_FEATHER_EXPRESS"
  #elif defined(NRF52832_FEATHER)
    #define BOARD_TYPE      "NRF52832_FEATHER"
  #elif defined(NRF52840_FEATHER_SENSE)
    #define BOARD_TYPE      "NRF52840_FEATHER_SENSE"
  #elif defined(NRF52840_ITSYBITSY)
    #define BOARD_TYPE      "NRF52840_ITSYBITSY_EXPRESS"
  #elif defined(NRF52840_CIRCUITPLAY)
    #define BOARD_TYPE      "NRF52840_CIRCUIT_PLAYGROUND"
  #elif defined(NRF52840_CLUE)
    #define BOARD_TYPE      "NRF52840_CLUE"
  #elif defined(NRF52840_METRO)
    #define BOARD_TYPE      "NRF52840_METRO_EXPRESS"
  #elif defined(NRF52840_PCA10056)
    #define BOARD_TYPE      "NORDIC_NRF52840DK"
  #elif defined(NINA_B302_ublox)
    #define BOARD_TYPE      "NINA_B302_ublox"
  #elif defined(NINA_B112_ublox)
    #define BOARD_TYPE      "NINA_B112_ublox"
  #elif defined(PARTICLE_XENON)
    #define BOARD_TYPE      "PARTICLE_XENON"
  #elif defined(MDBT50Q_RX)
    #define BOARD_TYPE      "RAYTAC_MDBT50Q_RX"
  #elif defined(ARDUINO_NRF52_ADAFRUIT)
    #define BOARD_TYPE      "ARDUINO_NRF52_ADAFRUIT"
  #else
    #define BOARD_TYPE      "nRF52 Unknown"
  #endif
#endif
#if ( defined(ARDUINO_SAM_DUE) || defined(__SAM3X8E__) )
  #if defined(WIFININA_USE_SAMDUE)
    #undef WIFININA_USE_SAMDUE
  #endif
  #define WIFININA_USE_SAMDUE      true
#endif
  // For SAM DUE
  #if defined(ARDUINO_SAM_DUE)
    #define BOARD_TYPE      "SAM DUE"
    #define BOARD_TYPE      "SAM SAM3X8E"
  #else
    #define BOARD_TYPE      "SAM Unknown"
  #endif
#endif
#if ( defined(STM32F0) || defined(STM32F1) || defined(STM32F2) || defined(STM32F3)  ||defined(STM32F4) || defined(STM32F7) || \
       defined(STM32L0) || defined(STM32L1) || defined(STM32L4) || defined(STM32H7)  ||defined(STM32G0) || defined(STM32G4) || \
       defined(STM32WB) || defined(STM32MP1) )
  #if defined(WIFININA_USE_STM32)
    #undef WIFININA_USE_STM32
  #endif
  #define WIFININA_USE_STM32      true
#endif
  #if defined(STM32F0)
    #warning STM32F0 board selected
    #define BOARD_TYPE  "STM32F0"
  #elif defined(STM32F1)
    #warning STM32F1 board selected
    #define BOARD_TYPE  "STM32F1"
  #elif defined(STM32F2)
    #warning STM32F2 board selected
    #define BOARD_TYPE  "STM32F2"
  #elif defined(STM32F3)
    #warning STM32F3 board selected
    #define BOARD_TYPE  "STM32F3"
  #elif defined(STM32F4)
    #warning STM32F4 board selected
    #define BOARD_TYPE  "STM32F4"
  #elif defined(STM32F7)
    #warning STM32F7 board selected
    #define BOARD_TYPE  "STM32F7"
  #elif defined(STM32L0)
    #warning STM32L0 board selected
    #define BOARD_TYPE  "STM32L0"
  #elif defined(STM32L1)
    #warning STM32L1 board selected
    #define BOARD_TYPE  "STM32L1"
  #elif defined(STM32L4)
    #warning STM32L4 board selected
    #define BOARD_TYPE  "STM32L4"
  #elif defined(STM32H7)
    #warning STM32H7 board selected
    #define BOARD_TYPE  "STM32H7"
  #elif defined(STM32G0)
    #warning STM32G0 board selected
    #define BOARD_TYPE  "STM32G0"
  #elif defined(STM32G4)
    #warning STM32G4 board selected
    #define BOARD_TYPE  "STM32G4"
  #elif defined(STM32WB)
    #warning STM32WB board selected
    #define BOARD_TYPE  "STM32WB"
  #elif defined(STM32MP1)
    #warning STM32MP1 board selected
    #define BOARD_TYPE  "STM32MP1"
  #else
    #warning STM32 unknown board selected
    #define BOARD_TYPE  "STM32 Unknown"
  #endif
#endif
#ifdef CORE_TEENSY
  #if defined(WIFININA_USE_TEENSY)
    #undef WIFININA_USE_TEENSY
  #endif
  #define WIFININA_USE_TEENSY      true
  #if defined(__IMXRT1062__)
    // For Teensy 4.1/4.0
    #define BOARD_TYPE      "TEENSY 4.1/4.0"
  #elif defined(__MK66FX1M0__)
    #define BOARD_TYPE "Teensy 3.6"
  #elif defined(__MK64FX512__)
    #define BOARD_TYPE "Teensy 3.5"
  #elif defined(__MKL26Z64__)
    #define BOARD_TYPE "Teensy LC"
  #elif defined(__MK20DX256__)
    #define BOARD_TYPE "Teensy 3.2" // and Teensy 3.1 (obsolete)
  #elif defined(__MK20DX128__)
    #define BOARD_TYPE "Teensy 3.0"
  #elif defined(__AVR_AT90USB1286__)
    #error Teensy 2.0++ not supported yet
  #elif defined(__AVR_ATmega32U4__)
    #error Teensy 2.0 not supported yet
  #else
    // For Other Boards
    #define BOARD_TYPE      "Unknown Teensy Board"
  #endif
#endif
#if ( defined(ARDUINO_ARCH_RP2040) || defined(ARDUINO_RASPBERRY_PI_PICO) || defined(ARDUINO_ADAFRUIT_FEATHER_RP2040) || defined(ARDUINO_GENERIC_RP2040) )
  #if defined(WIFININA_USE_RP2040)
    #undef WIFININA_USE_RP2040
  #endif
  #define WIFININA_USE_RP2040      true
  #if defined(ARDUINO_ARCH_MBED)
    #if defined(BOARD_NAME)
      #undef BOARD_NAME
    #endif
    #if defined(ARDUINO_NANO_RP2040_CONNECT)
      #define BOARD_NAME      "MBED NANO_RP2040_CONNECT"
    #elif defined(ARDUINO_RASPBERRY_PI_PICO)
      #define BOARD_NAME      "MBED RASPBERRY_PI_PICO"
    #elif defined(ARDUINO_ADAFRUIT_FEATHER_RP2040)
      #define BOARD_NAME      "MBED DAFRUIT_FEATHER_RP2040"
    #elif defined(ARDUINO_GENERIC_RP2040)
      #define BOARD_NAME      "MBED GENERIC_RP2040"
    #else
      #define BOARD_NAME      "MBED Unknown RP2040"
    #endif
  #endif
#endif
#if ( defined(__AVR_ATmega2560__) || defined(__AVR_ATmega2561__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega1281__) || \
      defined(__AVR_ATmega640__) || defined(__AVR_ATmega641__))
  #define BOARD_TYPE    "Arduino AVR Mega2560/ADK"
  #warning Using Arduino AVR Mega, Mega640(P), Mega2560/ADK.
#elif ( defined(__AVR_ATmega644__) || defined(__AVR_ATmega644A__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644PA__)  || \
        defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_NANO) || defined(ARDUINO_AVR_MINI) ||    defined(ARDUINO_AVR_ETHERNET) || \
        defined(ARDUINO_AVR_FIO) || defined(ARDUINO_AVR_BT)   || defined(ARDUINO_AVR_LILYPAD) || defined(ARDUINO_AVR_PRO)      || \
        defined(ARDUINO_AVR_NG) || defined(ARDUINO_AVR_UNO_WIFI_DEV_ED) || defined(ARDUINO_AVR_DUEMILANOVE) )
  #define BOARD_TYPE    "Arduino AVR UNO, Nano, etc."
  #warning Using Aduino AVR ATMega644(P), ATMega328(P) such as UNO, Nano.
#elif ( defined(ARDUINO_AVR_FEATHER328P) || defined(ARDUINO_AVR_METRO) || defined(ARDUINO_AVR_PROTRINKET5) || defined(ARDUINO_AVR_PROTRINKET3) || \
      defined(ARDUINO_AVR_PROTRINKET5FTDI) || defined(ARDUINO_AVR_PROTRINKET3FTDI) )
  #define BOARD_TYPE    "Adafruit AVR ATMega328(P)"
  #warning Using Adafruit ATMega328(P), such as AVR_FEATHER328P or AVR_METRO.
#elif ( defined(ARDUINO_AVR_LEONARDO) || defined(ARDUINO_AVR_LEONARDO_ETH) || defined(ARDUINO_AVR_YUN) || defined(ARDUINO_AVR_MICRO) || \
        defined(ARDUINO_AVR_ESPLORA)  || defined(ARDUINO_AVR_LILYPAD_USB)  || defined(ARDUINO_AVR_ROBOT_CONTROL) || defined(ARDUINO_AVR_ROBOT_MOTOR) || \
        defined(ARDUINO_AVR_CIRCUITPLAY)  || defined(ARDUINO_AVR_YUNMINI) || defined(ARDUINO_AVR_INDUSTRIAL101) || defined(ARDUINO_AVR_LININO_ONE) )
  #define BOARD_TYPE    "Arduino AVR ATMega32U4"
  #warning Using Arduino ATMega32U4, such as Leonardo or Leonardo ETH.
#elif ( defined(ARDUINO_AVR_FLORA8 ) || defined(ARDUINO_AVR_FEATHER32U4) || defined(ARDUINO_AVR_CIRCUITPLAY) || defined(ARDUINO_AVR_ITSYBITSY32U4_5V) || \
        defined(ARDUINO_AVR_ITSYBITSY32U4_3V)  || defined(ARDUINO_AVR_BLUEFRUITMICRO) || defined(ARDUINO_AVR_ADAFRUIT32U4) )
  #define BOARD_TYPE    "Adafruit AVR ATMega32U4"
  #warning Using Adafruit ATMega32U4, such as Feather_32u4, AVR_CIRCUITPLAY, etc.
#elif ( defined(__AVR_ATmega32U4__) || defined(ARDUINO_AVR_MAKEYMAKEY ) || defined(ARDUINO_AVR_PROMICRO) || defined(ARDUINO_AVR_FIOV3) || \
        defined(ARDUINO_AVR_QDUINOMINI) || defined(ARDUINO_AVR_LILYPAD_ARDUINO_USB_PLUS_BOARD ) )
  #define BOARD_TYPE    "Generic or Sparkfun AVR ATMega32U4"
  #warning Using Generic ATMega32U4, such as Sparkfun AVR_MAKEYMAKEY, AVR_PROMICRO, etc.
#elif ( defined(__AVR_ATmega328P__) || defined(ARDUINO_AVR_DIGITAL_SANDBOX ) || defined(ARDUINO_REDBOT) || defined(ARDUINO_AVR_SERIAL_7_SEGMENT) )
  #define BOARD_TYPE    "Generic or Sparkfun AVR ATMega328P"
  #warning Using Generic ATMega328P, such as Sparkfun AVR_DIGITAL_SANDBOX, REDBOT, etc.
#elif ( defined(__AVR_ATmega128RFA1__) || defined(ARDUINO_ATMEGA128RFA1_DEV_BOARD) )
  #define BOARD_TYPE    "Generic or Sparkfun AVR ATMega128RFA1"
  #warning Using Generic ATMega128RFA1, such as Sparkfun ATMEGA128RFA1_DEV_BOARD, etc.
#elif ( defined(ARDUINO_AVR_GEMMA) || defined(ARDUINO_AVR_TRINKET3) || defined(ARDUINO_AVR_TRINKET5) )
  #error These AVR boards are not supported! Please check your Tools->Board setting.
#endif
#if ( defined(__AVR_ATmega4809__) || defined(ARDUINO_AVR_UNO_WIFI_REV2) || defined(ARDUINO_AVR_NANO_EVERY) )
  #if !defined(BOARD_NAME)
    #if (ARDUINO_AVR_UNO_WIFI_REV2)
      #define BOARD_NAME      "megaAVR UNO WiFi Rev2"
    #elif (ARDUINO_AVR_NANO_EVERY)
      #define BOARD_NAME      "megaAVR Nano Every"
    #else
      #define BOARD_NAME      "megaAVR Unknown"
    #endif
  #endif
#endif
#ifndef BOARD_TYPE
  #define BOARD_TYPE    "Unknown board"
#endif
#ifndef BOARD_NAME
  #define BOARD_NAME    BOARD_TYPE
#endif
#define DEBUG_WIFININA_PORT     Serial
// Debug Level from 0 to 4
#define _WIFININA_LOGLEVEL_     1
#endif      //defines_h
plus un onglet secret a configurer
@philippe86220 salut l'ami
Bonjour @dfgh
Effectivement ...
Donc je retire ma question :mask:
Merci @dfgh
Bonne journée.
#include <SPI.h>
int vitesse = 0;
TinyGPSPlus gps;
   ss.begin(GPSBaud);
    // don't continue
    while (true);
    Serial.println(fv);
    //delay(10000);
  server.begin();
  printWiFiStatus();
     distancemaison =
          gps.location.lat(),
          gps.location.lng(),
          Maison_LAT,
          Maison_LON);}
  if (client)
        Serial.write(c);
    client.stop();
  Serial.println(ip);
  Serial.print(rssi);
onglet define
#ifndef defines_h
#define defines_h
  #endif
#endif
  #else
  #endif
#endif
  #endif
#endif
  #else
  #endif
#endif
  #endif
#endif
  // For SAM DUE
  #else
  #endif
#endif
  #endif
#endif
  #else
  #endif
#endif
#ifdef CORE_TEENSY
  #endif
  #else
    // For Other Boards
  #endif
#endif
  #endif
      #undef BOARD_NAME
    #endif
    #else
    #endif
  #endif
#endif
#endif
    #else
    #endif
  #endif
#endif
#ifndef BOARD_TYPE
#endif
#ifndef BOARD_NAME
#endif
#endif      //defines_h
Oui ok
C'est mieux comme ça.
Bonne journée à vous
@ enfant meme
pourrais tu remettre des coordonnées dans MAISON_LAT et MAISON_LON,
bien sur elles seront bidon, mais nous aurons la bonne syntaxe pour entrer les notres à la place.
merci
