Crgbarray not meshing with crgb in declarations
Hey there everybody. I'm trying to combine some codes and I'm having a bit of trouble. I already the "Cylon" FastLED code in part of my sketch, and I'm trying to merge to "TwinkleFox" FastLED code with it (among a few others), and I'm running into an issue. I thought that I had everything correct in my declarations, but when I go to verify my code, I get an error effectively stating that in my definitions the amount of LEDs is already assigned to a definition and that CRGBArray does not work since I already have a number value assigned to NUM_LEDS....
#include <FastLED.h>
#define LED_TYPE WS2811
#define COLOR_ORDER GRB
#define LED_PIN 6
#define DATA_PIN 6
#define VOLTS 12
#define MAX_MA 4000
#define LED_COUNT 100
#define NUM_LEDS 100
CRGB leds[NUM_LEDS];
CRGB gBackgroundColor = CRGB::Black;
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN);
CRGBArray<NUM_LEDS> leds;
#define TWINKLE_SPEED 6
#define TWINKLE_DENSITY 2
#define SECONDS_PER_PALETTE 5
#define AUTO_SELECT_BACKGROUND_COLOR 0
#define COOL_LIKE_INCANDESCENT 1
CRGBPalette16 gCurrentPalette;
CRGBPalette16 gTargetPalette;
This is what my definition section looks like, and if anybody could give me some input on what I can do to get these codes to merge, it would be hugely appreciated! Thank you!
Read the forum guidelines to see how to properly post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Is that the problem?
Why two different names for 100?b
Please remember to use code tags when posting code.
Hey sorry for the formatting issues.... Here is my whole code and my error message:
<Arduino: 1.8.15 (Windows 10), Board: "Arduino Uno"
In file included from C:\Users\madij\Documents\Arduino\Cylon_theaterchase\Cylon_theaterchase.ino:3:0:
C:\Users\madij\Documents\Arduino\libraries\FastLED\src/FastLED.h:14:21: note: #pragma message: FastLED version 3.004.000
pragma message "FastLED version 3.004.000"
Cylon_theaterchase:15:21: error: conflicting declaration 'CRGBArray<100> leds'
C:\Users\madij\Documents\Arduino\Cylon_theaterchase\Cylon_theaterchase.ino:14:6: note: previous declaration as 'CRGB leds [100]'
CRGB leds[NUM_LED];
C:\Users\madij\Documents\Arduino\Cylon_theaterchase\Cylon_theaterchase.ino: In function 'void loop()':
Cylon_theaterchase:283:21: error: invalid initialization of reference of type 'CRGBSet& {aka CPixelView&}' from expression of type 'CRGB [100]'
drawTwinkles( leds);
C:\Users\madij\Documents\Arduino\Cylon_theaterchase\Cylon_theaterchase.ino:329:6: note: in passing argument 1 of 'void drawTwinkles(CRGBSet&)'
void drawTwinkles( CRGBSet& L)
C:\Users\madij\Documents\Arduino\Cylon_theaterchase\Cylon_theaterchase.ino: In function 'void drawTwinkles(CRGBSet&)':
Cylon_theaterchase:356:10: error: 'gBackgroundColor' was not declared in this scope
 bg = gBackgroundColor; // just use the explicitly defined background color
exit status 1
conflicting declaration 'CRGBArray<100> leds'>
<[code]
#define LED_PIN 6
#define DATA_PIN 6
#define VOLTS 12
#define MAX_MA 4000
#define NUM_LED 100
CRGB leds[NUM_LED];
strip.begin();
strip.show();
strip.setBrightness(50);
Serial.begin(57600);
Serial.println("resetting");
LEDS.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
LEDS.setBrightness(84);
delay( 3000 ); //safety startup delay
FastLED.setMaxPowerInVoltsAndMilliamps( VOLTS, MAX_MA);
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS)
.setCorrection(TypicalLEDStrip);
chooseNextColorPalette(gTargetPalette);
void fadeall() {
for (int i = 0; i < NUM_LEDS; i++) {
leds[i].nscale8(250);
rainbow(5);
static uint8_t hue = 0;
Serial.print("x");
// First slide the led in one direction
// Set the i'th led to red
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
FastLED.show();
// now that we've shown the leds, reset the i'th led to black
// leds[i] = CRGB::Black;
fadeall();
// Wait a little bit before we loop around and do it again
delay(10);
Serial.print("x");
// Now go in the other direction.
for (int i = (NUM_LEDS) - 1; i >= 0; i--) {
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
Serial.print("x");
// Show the leds
FastLED.show();
fadeall();
delay(10);
theaterChaseRainbow(35);
EVERY_N_SECONDS( SECONDS_PER_PALETTE ) {
chooseNextColorPalette( gTargetPalette );
EVERY_N_MILLISECONDS( 10 ) {
nblendPaletteTowardPalette( gCurrentPalette, gTargetPalette, 12);
FastLED.show();
void theaterChaseRainbow(int wait) {
int firstPixelHue = 0; // First pixel starts at red (hue 0)
for (int a = 0; a < 300; a++) { // Repeat 30 times...
for (int b = 0; b < 3; b++) { // 'b' counts from 0 to 2...
strip.clear(); // Set all pixels in RAM to 0 (off)
// 'c' counts up from 'b' to end of strip in increments of 3...
for (int c = b; c < strip.numPixels(); c += 3) {
// hue of pixel 'c' is offset by an amount to make one full
// revolution of the color wheel (range 65536) along the length
// of the strip (strip.numPixels() steps):
int hue = firstPixelHue + c * 65536L / strip.numPixels();
uint32_t color = strip.gamma32(strip.ColorHSV(hue)); // hue -> RGB
strip.setPixelColor(c, color); // Set pixel 'c' to value 'color'
strip.show(); // Update strip with new contents
delay(wait); // Pause for a moment
firstPixelHue += 65536 / 90; // One cycle of color wheel over 90 frames
void rainbow(int wait) {
// Hue of first pixel runs 5 complete loops through the color wheel.
// Color wheel has a range of 65536 but it's OK if we roll over, so
// just count from 0 to 565536. Adding 256 to firstPixelHue each time
// means we'll make 5
65536/256 = 1280 passes through this outer loop:
for (long firstPixelHue = 0; firstPixelHue < 5 * 65536; firstPixelHue += 256) {
for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
// Offset pixel hue by an amount to make one full revolution of the
// color wheel (range of 65536) along the length of the strip
// (strip.numPixels() steps):
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
// strip.ColorHSV() can take 1 or 3 arguments: a hue (0 to 65535) or
// optionally add saturation and value (brightness) (each 0 to 255).
// Here we're using just the single-argument hue variant. The result
// is passed through strip.gamma32() to provide 'truer' colors
// before assigning to each pixel:
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
// "PRNG16" is the pseudorandom number generator
// It MUST be reset to the same starting value each time
// this function is called, so that the sequence of 'random'
// numbers that it generates is (paradoxically) stable.
uint16_t PRNG16 = 11337;
uint32_t clock32 = millis();
// Set up the background color, "bg".
// if AUTO_SELECT_BACKGROUND_COLOR == 1, and the first two colors of
// the current palette are identical, then a deeply faded version of
// that color is used for the background color
CRGB bg;
if ( (AUTO_SELECT_BACKGROUND_COLOR == 1) &&
(gCurrentPalette[0] == gCurrentPalette[1] )) {
bg = gCurrentPalette[0];
uint8_t bglight = bg.getAverageLight();
if ( bglight > 64) {
bg.nscale8_video( 16); // very bright, so scale to 1/16th
} else if ( bglight > 16) {
bg.nscale8_video( 64); // not that bright, so scale to 1/4th
bg.nscale8_video( 86); // dim, scale to 1/3rd.
uint8_t backgroundBrightness = bg.getAverageLight();
for ( CRGB& pixel : L) {
PRNG16 = (uint16_t)(PRNG16 * 2053) + 1384; // next 'random' number
uint16_t myclockoffset16 = PRNG16; // use that number as clock offset
// use that number as clock speed adjustment factor (in 8ths, from 8/8ths to 23/8ths)
uint8_t myspeedmultiplierQ5_3 = ((((PRNG16 & 0xFF) >> 4) + (PRNG16 & 0x0F)) & 0x0F) + 0x08;
uint32_t myclock30 = (uint32_t)((clock32 * myspeedmultiplierQ5_3) >> 3) + myclockoffset16;
uint8_t myunique8 = PRNG16 >> 8; // get 'salt' value for this pixel
// We now have the adjusted 'clock' for this pixel, now we call
// the function that computes what color the pixel should be based
// on the "brightness = f( time )" idea.
CRGB c = computeOneTwinkle( myclock30, myunique8);
uint8_t cbright = c.getAverageLight();
int16_t deltabright = cbright - backgroundBrightness;
if ( deltabright >= 32 || (!bg)) {
  // If the new pixel is significantly brighter than the background color,
  // use the new color.
  pixel = c;
} else if ( deltabright > 0 ) {
  // If the new pixel is just slightly brighter than the background color,
  // mix a blend of the new color and the background color
  pixel = blend( bg, c, deltabright * 8);
  // if the new pixel is not at all brighter than the background color,
  // just use the background color.
  pixel = bg;
// This function takes a time in pseudo-milliseconds,
// figures out brightness = f( time ), and also hue = f( time )
// The 'low digits' of the millisecond time are used as
// input to the brightness wave function.
// The 'high digits' are used to select a color, so that the color
// does not change over the course of the fade-in, fade-out
// of one cycle of the brightness wave function.
// The 'high digits' are also used to determine whether this pixel
// should light at all during this cycle, based on the TWINKLE_DENSITY.
CRGB computeOneTwinkle( uint32_t ms, uint8_t salt)
uint16_t ticks = ms >> (8 - TWINKLE_SPEED);
uint8_t fastcycle8 = ticks;
uint16_t slowcycle16 = (ticks >> 8) + salt;
slowcycle16 += sin8( slowcycle16);
slowcycle16 = (slowcycle16 * 2053) + 1384;
uint8_t slowcycle8 = (slowcycle16 & 0xFF) + (slowcycle16 >> 8);
uint8_t bright = 0;
if ( ((slowcycle8 & 0x0E) / 2) < TWINKLE_DENSITY) {
bright = attackDecayWave8( fastcycle8);
uint8_t hue = slowcycle8 - salt;
CRGB c;
if ( bright > 0) {
c = ColorFromPalette( gCurrentPalette, hue, bright, NOBLEND);
if ( COOL_LIKE_INCANDESCENT == 1 ) {
coolLikeIncandescent( c, fastcycle8);
c = CRGB::Black;
return c;
// This function is like 'triwave8', which produces a
// symmetrical up-and-down triangle sawtooth waveform, except that this
// function produces a triangle wave with a faster attack and a slower decay:
uint8_t attackDecayWave8( uint8_t i)
if ( i < 86) {
return i * 3;
i -= 86;
return 255 - (i + (i / 2));
// This function takes a pixel, and if its in the 'fading down'
// part of the cycle, it adjusts the color a little bit like the
// way that incandescent bulbs fade toward 'red' as they dim.
void coolLikeIncandescent( CRGB& c, uint8_t phase)
if ( phase < 128) return;
uint8_t cooling = (phase - 128) >> 4;
c.g = qsub8( c.g, cooling);
c.b = qsub8( c.b, cooling * 2);
// A mostly red palette with green accents and white trim.
// "CRGB::Gray" is used as white to keep the brightness more uniform.
const TProgmemRGBPalette16 RedGreenWhite_p FL_PROGMEM =
{ CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red,
CRGB::Red, CRGB::Red, CRGB::Gray, CRGB::Gray,
CRGB::Green, CRGB::Green, CRGB::Green, CRGB::Green
// A mostly (dark) green palette with red berries.
#define Holly_Green 0x00580c
#define Holly_Red 0xB00402
const TProgmemRGBPalette16 Holly_p FL_PROGMEM =
{ Holly_Green, Holly_Green, Holly_Green, Holly_Green,
Holly_Green, Holly_Green, Holly_Green, Holly_Red
// A red and white striped palette
const TProgmemRGBPalette16 RedWhite_p FL_PROGMEM =
CRGB::Gray, CRGB::Gray, CRGB::Gray, CRGB::Gray,
// A mostly blue palette with white accents.
const TProgmemRGBPalette16 BlueWhite_p FL_PROGMEM =
{ CRGB::Blue, CRGB::Blue, CRGB::Blue, CRGB::Blue,
CRGB::Blue, CRGB::Gray, CRGB::Gray, CRGB::Gray
// A pure "fairy light" palette with some brightness variations
#define HALFFAIRY ((CRGB::FairyLight & 0xFEFEFE) / 2)
#define QUARTERFAIRY ((CRGB::FairyLight & 0xFCFCFC) / 4)
const TProgmemRGBPalette16 FairyLight_p FL_PROGMEM =
{ CRGB::FairyLight, CRGB::FairyLight, CRGB::FairyLight, CRGB::FairyLight,
HALFFAIRY, HALFFAIRY, CRGB::FairyLight, CRGB::FairyLight,
QUARTERFAIRY, QUARTERFAIRY, CRGB::FairyLight, CRGB::FairyLight,
// A palette of soft snowflakes with the occasional bright one
const TProgmemRGBPalette16 Snow_p FL_PROGMEM =
{ 0x304048, 0x304048, 0x304048, 0x304048,
0x304048, 0x304048, 0x304048, 0xE0F0FF
// A palette reminiscent of large 'old-school' C9-size tree lights
// in the five classic colors: red, orange, green, blue, and white.
#define C9_Red 0xB80400
#define C9_Orange 0x902C02
#define C9_Green 0x046002
#define C9_Blue 0x070758
#define C9_White 0x606820
const TProgmemRGBPalette16 RetroC9_p FL_PROGMEM =
{ C9_Red, C9_Orange, C9_Red, C9_Orange,
C9_Orange, C9_Red, C9_Orange, C9_Red,
C9_Green, C9_Green, C9_Green, C9_Green,
C9_Blue, C9_Blue, C9_Blue,
C9_White
// A cold, icy pale blue palette
#define Ice_Blue1 0x0C1040
#define Ice_Blue2 0x182080
#define Ice_Blue3 0x5080C0
const TProgmemRGBPalette16 Ice_p FL_PROGMEM =
Ice_Blue1, Ice_Blue1, Ice_Blue1, Ice_Blue1,
Ice_Blue2, Ice_Blue2, Ice_Blue2, Ice_Blue3
// Add or remove palette names from this list to control which color
// palettes are used, and in what order.
const TProgmemRGBPalette16* ActivePaletteList[] = {
&RainbowColors_p,
&FairyLight_p,
&PartyColors_p,
&FairyLight_p,
// Advance to the next color palette in the list (above).
void chooseNextColorPalette( CRGBPalette16& pal)
const uint8_t numberOfPalettes = sizeof(ActivePaletteList) / sizeof(ActivePaletteList[0]);
static uint8_t whichPalette = -1;
whichPalette = addmod8( whichPalette, 1, numberOfPalettes);
pal = *(ActivePaletteList[whichPalette]);
[/code]>
I'm extremely new to working with Arduino, and have no previous coding experience, so this has been like going through the ringer hahaha. I have 2 different names for the 100 because when I remove the CRGBArray, it tells me I have an invalid initialization of reference.... I'm not sure why one set of code calls on the CRGBArray, and one will simply except the other version...
Post code in code tags.
You can't have two separate variables named "leds". You will have to rename one of the two. The sketch that was using the variable you rename will have to use the new name.
 #    pragma message "FastLED version 3.004.000"
 CRGB leds[NUM_LED];
Cylon_theaterchase:284:21: error: invalid initialization of reference of type 'CRGBSet& {aka CPixelView<CRGB>&}' from expression of type 'CRGB [100]'
C:\Users\madij\Documents\Arduino\Cylon_theaterchase\Cylon_theaterchase.ino:330:6: note: in passing argument 1 of 'void drawTwinkles(CRGBSet&)'
exit status 1
option enabled in File -> Preferences.
[code]
#define LED_PIN   6
#define DATA_PIN  6
#define VOLTS          12
#define MAX_MA       4000
#define NUM_LED 100
CRGB leds[NUM_LED];
    strip.begin();
    strip.show();
void fadeall() {
  rainbow(5);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10);
  Serial.print("x");
    // Show the leds
    FastLED.show();
    fadeall();
    delay(10); \
  FastLED.show();
  // just count from 0 to 5*65536. Adding 256 to firstPixelHue each time
  // means we'll make 5*65536/256 = 1280 passes through this outer loop:
  CRGB bg;
      pixel = c;
      pixel = bg;
  uint8_t bright = 0;
  CRGB c;
  if ( bright > 0) {
    c = CRGB::Black;
  return c;
  if ( i < 86) {
    return i * 3;
    i -= 86;
  C9_White
  &RainbowColors_p,
  &FairyLight_p,
  &PartyColors_p,
  &FairyLight_p,
[/code]
You've still got two entities called "leds"
So I edited the code to not include both leds, which says that my code is accurate, but now when I actually upload them to my lights, the final twinkle sequence won't run, even though when I verify my code everything says it's correct. Unsure why it is excluding just one of my sequences....
Is that the sequence that used the 'leds' that you deleted or renamed?
No all sketches that compile without errors will do what you want them to. They can only do what you tell them to.
I had simply removed the section of code #define NUM_LED and left the one labeled LEDarray. I also tried to pull some simple adafruit code into the sketch that I am trying to compile with my larger sketch, and I was having similar issues where the adafruit pattern I added nullified the twinkle pattern that I added it to. No alterations to the original code, just tried to add the necessary code to have a second flashing pattern accompany the twinkle.
Thank you guys for all your help!
