Crooked ATmega328P on new board
Hello all,
I'm brand new to all of this. My first board (UNO Rev3) just showed up and it looks to me like the chip is crooked. It seems to be much higher up on one end than the other (I would upload a photo to clarify the issue but am unable as a new user).
I'm hoping someone might be able to tell me whether or not this is an issue.
Thanks in advance!
Does the Uno work? Try uploading the Blink sketch.
Which chip? There are several on the Uno board. The main processor is socketed and can be removed and reseated.
Hi @lulululu12345. You will be able to upload photos once you reach "trust level 1" with the Discourse forum software used here.
The requirements for reaching "trust level 1" are very minimal and can be attained after only a matter of minutes. You might have even reached them already since the time you created your post. You can learn them here:
I do think a picture would be helpful to this particular discussion.
If this is like my old UNO, the processor is in a socket. IS yours? If so, just use your fingers to press it all the way down into the socket.
If it works at all, try each of the pins. If they all work, you are fine. It isn't going anywhere after it is soldered down.
That did the trick!
Thank you so much
Thanks to all of you for the helpful answers.
It's a nice welcome to the arduino community :slight_smile:
