Hi NoblePepper,
I know you are very good at this !
As advised by you in previously, I have successfully built all the toolchain from ground zero and compiled simple C++ Program. (so far good, running flawlessly in Arduino)
Now in another C++ program I am using CURL library and including <curl/curl.h> and linking with -l curl library.
g++ compiler on ubuntu machine compiles this code and runs without any issues.
When I am cross compiling the code for Arduino Linino using mips-openwrt-linux-g++ it says cannot find <curl/curl.h>
I have added the file path to $PATH and also includes -B "/home/ubuntu/linino/trunk/staging_dir/target-mips_r2_uClibc-0.9.33.2/usr/include" command line option. Still this compiler is complaining cannot find curl/curl.h file Not sure what is going on here
Looks like I need to set the PATH somewhere else which I am not sure.
Any help from you is highly appreciated.
Also: I believe you are using Eclipse for the Cross compilation right. Can you point me to documentation on this as well? I might as well start using Eclipse.
Thank you in advance and appreciate any input on this. I am stuck here.
I have learned most of the options I know by watching what Eclipse does, it makes it a lot easier to find what is needed but it is a system to learn all on it's own.
I got everything up and running on the Arduino now. As advised, I will start using Eclipse.
Currently, I am using UBUNTU LINUX . Latest version. I can install Eclipse on that and cross compile all the C/C++ programs right ?
One more thing I need to ask is : Is it possible to upload a small c program on the Arduino ATMega32U4 Processor running parallel with Sketch. or It runs only one Sketch. any thoughts on that.
I am running Eclipse Juno on Ubuntu 13.04, the newer versions of Ubuntu should be fine. It looks like the 12.xx versions of Ubuntu are fine too.
The howto I pointed you toward is written for Eclipse Indigo so it will match that exactly, and would be easiest to use with it.
I think some things were in different places in Juno. I tried Kepler but ran into some issues with compiling for Arduinos on it and went back to Juno but I never tried the OpenWrt setup on Kepler so I don't know if it will work with OpenWrt or not.
A sketch is a C++ program, the IDE hides it from the user but all of the sketch code is C++ and linked to Arduino libraries. There are some options to "multitask" on the AVR but I don't see the point myself.
