Crouzet M2l
Hi all,
I hope this is ok to post here.
I need some help wiring up this timer relay device: Crouzet M2L.
I have checked on the manufacturers website for a data sheet
but I am still not clear how to wire it up correctly.
Looks like the power goes to A1 and A2.
just not sure whether I can put a live load across terminals 15 and 16.
If anyone can throw light on this (pun intended) I would be very grateful.
Thanks in advance,
keef
Yes, you can put live (up to 240 volts and 8 Amperes) on 15 (common) and have your load at 16 (Normally Closed) if you want to switch off your load when the relay is activated.
If you want to switch on your load upon activation, connect it to 18 (Normally Open).
Of course you need to set the on time as well as the off time.
Great,
thanks for your very clear reply.
keef
