Crypt not working in all positions
i made the following function:
bool XOR_cryptDecryptChar(char * input)
  int insize = strlen(input);
  char key1[5] = {'K', 'C', 'Q', 'R','F'};
  for(int x=0; x<insize; x++)
    input[x] = input[x] ^ key1[x % (sizeof(key1) / sizeof(char))];
  return true;
The code works ok for small lenght chars, but i have passed a char variable with 1756 positions, and only the first 272 are crypted, all the remaining text disappears, i can't figure out why. Any ideas ?
As said in the other thread, "strlen" will count the characters until a null-character is found. When you XOR a value with it self, it will become zero/null, so "strlen" is only valid for plain text.
Hi Danois,
but it's still something i am not understading, let me explain what i have done:
1 => First i call this function passing plain text. This char has 1756 positions in plain text.
2 => the function passes through all positions, but the output only shows around 125 chars.
When i make the int insize = strlen(input), this gives the correct lenght of the char, so that's why i am not understading.
This is an example what i am trying to encrypt, it's random text for test purposes:
{"fileVersion":"1.0.0","brokerURL":"192.168.1.1","brokerPort":"1883","brokerUsername":"hello","brokerPassword":"world","brokerClientId":"48371129","brokerGeneralTopic":"IOT/nme12e/in","brokerGlobalTopic":"IOT/global/in","useAuthentication":"1","publishQoS":"1","willQoS":"1","willRetain":"1","willMessage":"Disconnected!","willMessage1":"SDS345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345VAZSDSdfklsdlkfsdklfskdlflsdjkfksdjlfjskdlfkjlsfkjlsdflksdflkslkjrrtioertioeroitreuiot34458435983489589345ZAV"}
Danois90:
The function in #1 is only valid for encryption, if you use "strlen" on an encrypted buffer, it will only count characters until the for null-char is found and not the entire buffer. You need to store the length of the plaintext message and use the stored value for decryption instead of "strlen".
Yes, i understood, but my problem is that on function #1, when encrypted plain text, only first 126 characters of that example are crypted and i dont understand why
Danois90:
How do you know that only the first 126 characters are being encrypted?
whoops... my bad man, i had a bug in code, however, i was not taking in consideration to store the lenght after crypt the values, it's now all working fine, many, many thanks! i've been struggling with this for a week now :slight_smile:
Thanks!!!
Danois90:
