Hi all,
Having a tuning issue with my Arduino mega2560 running the attached sketch.
Note: this sketch ran OK with Arduino Uno.
int Pwmpin = 11 ; //Pwm Output Pin
int Fchange = A0; //Frequency change through Potentiometer
pinMode(Pwmpin, OUTPUT);
TCCR1A = _BV(COM1A1) | _BV(COM1B1); //Non-inverted Mode
TCCR1B = _BV(WGM13) | _BV(CS11); //Prescalar 8
float frequency = 440 + (analogRead(A0) * 0) / 1024;
uint16_t TOP = ((F_CPU / 8) / (frequency * 2)) - 1;
ICR1 = TOP;
OCR1A = TOP / 1.5;
I checked the frequency with a chromatic tuner.
The result was 4 to 5 hz low (flat).
For maths convenience i selected 4.4 hz.
my calculation is as follows:
4.4/440 x 16,000,000 = 160,000 hz
I then checked the clock using the Fade sketch.
The result was 495 to 496 milli hz. 4 to 5 milli hz low.
Again for maths convenience i selected 5 milli hz
my calculation is as follows;
5/500 x 16,000,000 = 160,000 hz.
Both suggest the clock is +/- 10,000 ppm , in this case minus.
If my maths is right , then the clock is kaput.
Any thoughts?
