Crystal for Arduino Standalone
On the parts list for the Arduino Standalone, the following part is listed: Q1 16MHz CRYSTAL 16.000 MHZ HC49/US 300-6034-ND
Unfortunately, Digi-Key no longer seems to stock it. What would be a good part to use instead? Could I just substitute any with the same package, clock speed, and capacitance?
Thanks!
That should work fine. That's what I did, except I goofed and got the full-height (49/U, I think?) package. The crystal works just fine, but it stands out :) because it's so tall.
It's not the correct way to do things but I find that, for most of my tinkering applications, if I root around in the junk box and find a crystal with the right frequency it works. I don't worry about parallel vs. series and the capacitance, if it means I can get away without placing an order to get the "right" one. -j
Thanks!
Digikey 300-8499-ND works fine.
D.
