Crystal oscillator on Lenoanrdo....
Is there a reason why the crystal oscillator on the Leonardo is different from the crystal on the Uno? Could you put the crystal on the uno on the Leonardo?
Yes.
The Uno uses a separate Atmega16U2 for the serial communications and that uC has a crystal for the timebase to ensure accurate serial communications at high BAUD rates. The Atmega328P-PU uC is not doing critical communications, therefore a less expensive ceramic resonator is used.
The Leonardo uses a single 32U4 for the entire board, communications and computing. A crystal is more appropriate in this case.
There are some clones out in the Leonardo world that may use resonators. The Arduino official description is:
The Arduino Leonardo is a microcontroller board based on the ATmega32u4 (datasheet). It has 20 digital input/output pins (of which 7 can be used as PWM outputs and 12 as analog inputs), a 16 MHz crystal oscillator, a micro USB connection, a power jack, an ICSP header, and a reset button.
One would be ill-advised to put a resonator on the Leonardo.
Ray
