Crystal vs Clock Oscilator
Hello everyone,
I have some experience with microcontrolers but much less experience with Arduino specifics.
My problem is this:
I want to connect an ATMEGA328 directly to a clock line (no crystal or ressonator).
Does the Arduino Bootloader configure the chip to accept clock inputs just on OSC1 pin?
Base Arduino board is Arduino Pro Mini @ 3.3V
Thanks in advance,
Mike
It seems to be a fuse setting. The bootloader has nothing to do with clock source. Read 328 data sheet chapter 9 system clock and clock options, sections 2 and 8 about clock sources and external clock. There are 3 options for accepting external clock signals, each with more startup time than the last.
Thank you liudr for your help. It helped me imensely.
You are welcome. I had a hunch so I did some reading myself. I might just try that in a breadboard setup myself with 2 mcus.
