Hello friends,
I am trying to use CS5532 24-bit ADC via SPI interfacing to Arduino Due. I changed a lot of things on my code , but I always read 111111111111. What is the error ?
Here is the codes
#include <SPI.h>
#include "CS5532_lib.h" // cs5532 definitions.
#define CS5532_CS_PIN 4
#define CS5532_READY MISO
#define CS5532_CS_LOW digitalWrite(CS5532_CS_PIN,LOW);
#define CS5532_CS_HIGH digitalWrite(CS5532_CS_PIN,HIGH);
void SPI_Writing_Word (unsigned int data)
SPI.transfer(CS5532_CS_PIN,(data >> 8) & 0xFF);
SPI.transfer(CS5532_CS_PIN,data & 0xFF);
void SPI_Writing_Long (unsigned long int data)
SPI.transfer(CS5532_CS_PIN,(data >> 24) & 0xFF);
SPI.transfer(CS5532_CS_PIN,(data >> 16) & 0xFF);
unsigned long int SPI_Reading_Long()
unsigned long ret = 0;
ret = SPI.transfer(CS5532_CS_PIN,0);
ret = (ret << 8) + SPI.transfer(CS5532_CS_PIN,0);
return ret;
unsigned long int CS5532_Reset(void)
SPI.transfer(CS5532_CS_PIN,CS5532_CMD_WRITE_CONF);
SPI_Writing_Long(0x20000000);
delay(1);
SPI_Writing_Long(0x00000000);
SPI.transfer(CS5532_CS_PIN,CS5532_CMD_READ_CONF);
return SPI_Reading_Long();
unsigned long int CS5532_Init(void)
CS5532_CS_LOW;
char i = 0;
//reset precedure
for (i=0; i<15; i++)
SPI.transfer(CS5532_CS_PIN, CS5532_SYNC1);
SPI.transfer(CS5532_CS_PIN, CS5532_SYNC0);
// CS5532_CS_HIGH;
return CS5532_Reset();
void CS5532_Config(void)
SPI.transfer(CS5532_CMD_WRITE_INDV_CH_SETUP1);
SPI_Writing_Long(0x02000000);
SPI.transfer(CS5532_CMD_WRITE_CONF);
void CS5532_Single_Conversion(void)
CS5532_CS_LOW;
SPI.transfer(CS5532_CS_PIN, CS5532_CMD_SINGLE_CONV_CH_SETUP1);
// CS5532_CS_HIGH;
void CS5532_Continuous_Conversion(void)
CS5532_CS_LOW;
SPI.transfer(CS5532_CS_PIN,CS5532_CMD_CONTINUOUS_CONV_CH_SETUP1);
// CS5532_CS_HIGH;
char CS5532_ReadADC(unsigned char *DataBuff)
unsigned char i;
unsigned char *p_DataBuff;
p_DataBuff = DataBuff;
digitalRead(CS5532_READY);
if(CS5532_READY == 1)
return(0XFF);
// CS5532_CS_LOW;
// SPI.transfer(CS5532_CS_PIN,CS5532_NULL);
for(i = 4; i > 0; i--)
*p_DataBuff++ = SPI.transfer(CS5532_CS_PIN,0);
// CS5532_CS_HIGH;
return(0x0);
void init_CS5532(void)
int i=3;
for(i=3;i>0;i--)
if(CS5532_Init() == 0x10000000)
CS5532_Config();
CS5532_Single_Conversion();
SPI.begin(4);
digitalWrite(CS5532_CS_PIN, OUTPUT);
SPI.setDataMode(CS5532_CS_PIN,SPI_MODE3);
SPI.setBitOrder(LSBFIRST);
//pinMode (CS5532_CS_PIN, OUTPUT);
//SPI.setClockDivider(SPI_CLOCK_DIV4);
SPI.setClockDivider(CS5532_CS_PIN,2); // arduino DUE
Serial.println("sending...");
delay(2000);
CS5532_Init();
init_CS5532();
Serial.println("All is Done");
unsigned char tempbuff[4] = {0, 0, 0 ,0};
float data;
Serial.print("rawdata:");
// CS5532_CS_LOW;
CS5532_ReadADC(tempbuff);
// CS5532_CS_HIGH;
Serial.print(tempbuff[0],BIN);
Serial.print(tempbuff[1],BIN);
Serial.print(tempbuff[2],BIN);
// Serial.print(" birsifirsifir");
// Serial.println(tempbuff[3],BIN);
//End
This is the header file.
* CS5532 Library
* Meric SARIISIK
* 7/2015
#ifndef __CS5532_H__
#define __CS5532_H__
#define CS5532_SYNC1 0XFF //Part of the serial port re-initialization sequence.
#define CS5532_SYNC0 0XFE //End of the serial port re-initialization sequence.
#define CS5532_NULL 0X00 //This command is used to clear a port flag and keep the converter in the continuous conversion mode.
//Command Register (CS5532_COMM_REG)
#define CS5532_COMM_C (1 << 7) //D7 Command Bit, C
#define CS5532_COMM_ARA (1 << 6) //D6 Access Registers as Arrays, ARA
#define CS5532_COMM_CS (((x) & 0x3) << 4) //D5-D4 Channel Select Bits,CS1-CS0
#define CS5532_COMM_READ (1 << 3) //D3 Read/Write, R/W
#define CS5532_COMM_WRITE (0 << 3)
#define CS5532_COMM_RSB (((x) & 0x7) << 0) //D2-D0 Register Select Bit,RSB3-RSB0
//alıntı
#define CS5532_READ_DATA_TIMEOUT 2000000 //4.9152 MHz crystal takes 20ms to start
//Command Register Descriptions
/*READ/WRITE ALL OFFSET CALIBRATION REGISTERS*/
#define CS5532_CMD_READ_ALL_OFFSET_CAL 0x49
#define CS5532_CMD_WRITE_ALL_OFFSET_CAL 0x41
/*READ/WRITE ALL GAIN CALIBRATION REGISTERS*/
#define CS5532_CMD_READ_ALL_GAIN_CAL 0x4A
#define CS5532_CMD_WRITE_ALL_GAIN_CAL 0x42
/*READ/WRITE ALL CHANNEL-SETUP REGISTERS*/
#define CS5532_CMD_READ_ALL_CH_SETUP 0x4D
#define CS5532_CMD_WRITE_ALL_CH_SETUP 0x45
/*READ/WRITE INDIVIDUAL OFFSET REGISTER*/
#define CS5532_CMD_READ_ALL_INDV_OFFSET1 0x9
#define CS5532_CMD_WRITE_ALL_INDV_OFFSET1 0x1
#define CS5532_CMD_READ_ALL_INDV_OFFSET2 0x19
#define CS5532_CMD_WRITE_ALL_INDV_OFFSET2 0x11
/*READ/WRITE INDIVIDUAL GAIN REGISTER*/
#define CS5532_CMD_READ_INDV_GAIN1 0xA
#define CS5532_CMD_WRITE_INDV_GAIN1 0x2
#define CS5532_CMD_READ_INDV_GAIN2 0x1A
#define CS5532_CMD_WRITE_INDV_GAIN2 0x12
/*READ/WRITE INDIVIDUAL CHANNEL-SETUP REGISTER*/
#define CS5532_CMD_READ_INDV_CH_SETUP1 0xD
#define CS5532_CMD_WRITE_INDV_CH_SETUP1 0x5
#define CS5532_CMD_READ_INDV_CH_SETUP2 0x1D
#define CS5532_CMD_WRITE_INDV_CH_SETUP2 0x15
#define CS5532_CMD_READ_INDV_CH_SETUP3 0x2D
#define CS5532_CMD_WRITE_INDV_CH_SETUP3 0x25
#define CS5532_CMD_READ_INDV_CH_SETUP4 0x3D
#define CS5532_CMD_WRITE_INDV_CH_SETUP4 0x35
/*READ/WRITE CONFIGURATION REGISTER*/
#define CS5532_CMD_READ_CONF 0xB
#define CS5532_CMD_WRITE_CONF 0x3
/*PERFORM CONVERSION*/
//Perform a single conversion.
#define CS5532_CMD_SINGLE_CONV_CH_SETUP1 0X80
#define CS5532_CMD_SINGLE_CONV_CH_SETUP2 0X88
#define CS5532_CMD_SINGLE_CONV_CH_SETUP3 0X90
#define CS5532_CMD_SINGLE_CONV_CH_SETUP4 0X98
#define CS5532_CMD_SINGLE_CONV_CH_SETUP5 0XA0
#define CS5532_CMD_SINGLE_CONV_CH_SETUP6 0XA8
#define CS5532_CMD_SINGLE_CONV_CH_SETUP7 0XB0
#define CS5532_CMD_SINGLE_CONV_CH_SETUP8 0XB8
//Perform continuous conversions.
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP1 0XC0
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP2 0XC8
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP3 0XD0
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP4 0XD8
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP5 0XE0
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP6 0XE8
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP7 0XF0
#define CS5532_CMD_CONTINUOUS_CONV_CH_SETUP8 0XF8
/*PERFORM CALIBRATION*/
//001 Self-Offset Calibration
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP1 0X81
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP2 0X89
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP3 0X91
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP4 0X99
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP5 0XA1
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP6 0XA9
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP7 0XB1
#define CS5532_CMD_SELF_OFFSET_CALIB_SETUP8 0XB9
//010 Self-Gain Calibration
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP1 0X82
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP2 0X8A
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP3 0X92
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP4 0X9A
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP5 0XA2
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP6 0XAA
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP7 0XB2
#define CS5532_CMD_SELF_GAIN_CALIB_SETUP8 0XBA
//101 System-Offset Calibration
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP1 0X85
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP2 0X8D
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP3 0X95
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP4 0X9D
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP5 0XA5
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP6 0XAD
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP7 0XB5
#define CS5532_CMD_SYS_OFFSET_CALIB_SETUP8 0XBD
//110 System-Gain Calibration
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP1 0X86
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP2 0X8E
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP3 0X96
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP4 0X9E
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP5 0XA6
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP6 0XAE
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP7 0XB6
#define CS5532_CMD_SYS_GAIN_CALIB_SETUP8 0XBE
//2.3.9. Configuration Register Descriptions
#define CS5532_PSS 1 << 31 //Power Save Select
#define CS5532_PDW 1 << 30 //Power Down Mode
#define CS5532_RS 1 << 29 //Reset System
#define CS5532_RV 1 << 28 //Reset Valid
#define CS5532_IS 1 << 27 //Input Short
#define CS5532_GB 1 << 26 //Guard Signal Bit
#define CS5532_VRS 1 << 25 //Voltage Reference Select
#define CS5532_OLS 1 << 22 //Output Latch Select
#define CS5532_OGS 1 << 20 //Offset and Gain Select
#define CS5532_FRS 1 << 19 //Filter Rate Select
//2.4.1. Channel-Setup Register
//Channel Select Bits
#define CS5532_CS1 0 << 14
#define CS5532_CS2 1 << 14
//Gain Bits
#define CS5532_GAIN_1 0 << 11
#define CS5532_GAIN_2 1 << 11
#define CS5532_GAIN_4 2 << 11
#define CS5532_GAIN_8 3 << 11
#define CS5532_GAIN_16 4 << 11
#define CS5532_GAIN_32 5 << 11
#define CS5532_GAIN_64 6 << 11
//Word Rate when FSR=1
#define CS5532_WR_100SPS 0x0 << 7
#define CS5532_WR_50SPS 0x1 << 7
#define CS5532_WR_25SPS 0x2 << 7
#define CS5532_WR_12P5SPS 0x3 << 7
#define CS5532_WR_6P25SPS 0x4 << 7
#define CS5532_WR_3200SPS 0x8 << 7
#define CS5532_WR_1600SPS 0x9 << 7
#define CS5532_WR_800SPS 0xA << 7
#define CS5532_WR_400SPS 0xB << 7
#define CS5532_WR_200SPS 0xC << 7
//Unipolar / Bipolar
#define CS5532_UNIPOLAR 1 << 6
#define CS5532_BIPOLAR 0 << 6
//Output Latch Bits
#define CS5532_OL0 0 << 4
#define CS5532_OL1 1 << 4 //should Select!
#define CS5532_OL2 2 << 4
#define CS5532_OL3 3 << 4
//Delay Time Bit
#define CS5532_DT0 0 << 3
#define CS5532_DT1 1 << 3 //should select!
//Open Circuit Detect Bit
#define CS5532_OCD0 0 << 2
#define CS5532_OCD1 1 << 2 //should select!
//Offset / Gain Register Pointer Bits
#define CS5532_OG0 0
#define CS5532_OG1 1
//alıntı
#define CMD_STOP_CONT_CONV 0xFF
#define TIMEOUTERR 0xff
#define SUCCESSFUL 0x0
#define CAL_TIMEOUT_LIMIT 4000
/*!< Initializes the SPI communication peripheral. */
unsigned char SPI_Init(unsigned char lsbFirst,
unsigned long clockFreq,
unsigned char clockPol,
unsigned char clockEdg);
/*!< Writes data to SPI. */
unsigned char SPI_Write(unsigned char slaveDeviceId,
unsigned char* data,
unsigned char bytesNumber);
/*!< Reads data from SPI. */
unsigned char SPI_Read(unsigned char slaveDeviceId,
#endif
Hi before I try this new software I would ask if I can use arduino and if I can adapt qusto software to a CS5534, I realized with a shield for arduino with this component. thanks in advance for your help
