CT Coil False Readings With Sinric
Hey,
I am trying to get a CT Sensor to see if there is Current in a light cable then it will update Sinric to On or Off depending on what the Current value is.
I have an issue with the CT output when it is built into the Sinric sketch, the CT value reads 104 whether the light is or or not. I have installed a test sketch
// EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3
#include "EmonLib.h"                   // Include Emon Library
EnergyMonitor emon1;                   // Create an instance
  emon1.current(A0, 111.1);             // Current: input pin, calibration.
  double Irms = emon1.calcIrms(1480);  // Calculate Irms only
  Serial.print(Irms*120.0);         // Apparent power
  Serial.print(" Watts   ");
  Serial.print(Irms);          // Irms
  Serial.println(" Amps_..");
Which works as it should, when the light is on it shows current and when it is off it shows no current.
If anyone could have a look at my code below and offer any suggestions it would be amazing as i am now running out of ideas.
 Version 0.3 - March 06 2018
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsClient.h> //  https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
#include <ArduinoJson.h> // https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
#include <StreamString.h>
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
const int ledPin = D1;
#define MyApiKey "***" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "***" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "***" // TODO: Change to your Wifi network password
int lightstatus;
int ctreading;
//#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
#define HEARTBEAT_INTERVAL 60000 // 1 Minute
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
void setPowerStateOnServer(String deviceId, String value);
//void setTargetTemperatureOnServer(String deviceId, String value, String scale);
// deviceId is the ID assgined to your smart-home-device in sinric.com dashboard. Copy it from dashboard and paste it here
void turnOn(String deviceId) {
  if (deviceId == "***")
    if (lightstatus == 0)
    digitalWrite(ledPin, !digitalRead(ledPin));
    Serial.print("Turn on device id: ");
    Serial.println(deviceId);
   // digitalWrite(ledPin, HIGH);
    setPowerStateOnServer("***", "ON");
    lightstatus = 1;
      Serial.println("light Is Already On");
    Serial.print("Turn on for unknown device id: ");
void turnOff(String deviceId) {
   if (deviceId == "***") // Device ID of first device
    if (lightstatus == 1)
     Serial.print("Turn off Device ID: ");
     //digitalWrite(ledPin, HIGH);
     setPowerStateOnServer("***", "OFF");
     lightstatus = 0;
      Serial.println("light Is Already Off");
     Serial.print("Turn off for unknown device id: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
  switch(type) {
    case WStype_DISCONNECTED:
      Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
    case WStype_CONNECTED: {
      isConnected = true;
      Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
      Serial.printf("Waiting for commands from sinric.com ...\n");
    case WStype_TEXT: {
        Serial.printf("[WSc] get text: %s\n", payload);
        // Example payloads
        // For Switch or Light device types
        // {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // https://developer.amazon.com/docs/device-apis/alexa-powercontroller.html
        // For Light device type
        // Look at the light example in github
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject((char*)payload);
        String deviceId = json ["deviceId"];
        String action = json ["action"];
        if(action == "setPowerState" || action == "SetBrightness") { // Switch or Light
            String value = json ["value"];
            if ((value == "ON") && (value >= "50")) {
                turnOn(deviceId);
                turnOff(deviceId);
        else if (action == "test") {
            Serial.println("[WSc] received test command from sinric.com");
           //setPowerStateOnServer("***", "ON");
    case WStype_BIN:
      Serial.printf("[WSc] get binary length: %u\n", length);
  WiFiMulti.addAP(MySSID, MyWifiPassword);
  Serial.print("Connecting to Wifi: ");
  Serial.println(MySSID);
  // Waiting for Wifi connect
  while(WiFiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
  if(WiFiMulti.run() == WL_CONNECTED) {
    Serial.println("");
    Serial.print("WiFi connected. ");
    Serial.print("IP address: ");
  pinMode(ledPin, OUTPUT); // initialize digital ledPin as an output.
  delay(10);
  digitalWrite(ledPin, HIGH); // Wemos BUILTIN_LED is active Low, so high is off
  // server address, port and URL
  webSocket.begin("iot.sinric.com", 80, "/");
  // event handler
  webSocket.onEvent(webSocketEvent);
  webSocket.setAuthorization("apikey", MyApiKey);
  // try again every 5000ms if connection has failed
  webSocket.setReconnectInterval(5000);   // If you see 'class WebSocketsClient' has no member named 'setReconnectInterval' error update arduinoWebSockets
  webSocket.loop();
  if(isConnected) {
      uint64_t now = millis();
      // Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
      if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
          heartbeatTimestamp = now;
          webSocket.sendTXT("H");
  int volts = 1.0;
  if (Irms >= volts)
    Serial.print("Light Is On ");
    Serial.println(Irms);
    ctreading = (Irms);
    lightstatus = 1;
    Serial.print("CT Reading Is ");
    Serial.println(ctreading);
    Serial.print("Light Status Is ");
    Serial.println(lightstatus);
    Serial.print("Light Is Off ");
    ctreading = (Irms);
    lightstatus = 0;
// If you are going to use a push button to on/off the switch manually, use this function to update the status on the server
// so it will reflect on Alexa app.
void setPowerStateOnServer(String deviceId, String value) {
  JsonObject& root = jsonBuffer.createObject();
  root["deviceId"] = deviceId;
  root["action"] = "setPowerState";
  root["value"] = value;
  StreamString databuf;
  root.printTo(databuf);
  webSocket.sendTXT(databuf);
Suggestion! Show a link to the sensor data sheet or technical info.
Paul
You've not initialized emon1. You need to call emon1.current() - take the current only example and start there.
