CT77 temp sensor with SPI
I have problem with read data from a CT77 temp sensor.
#include "SPI.h"
 int CSPin = 4;      //
 byte byte1;
 byte byte2;
 int32_t temp;
   pinMode(CSPin, OUTPUT); //
   digitalWrite(CSPin, HIGH);
   SPI.begin(); // wake up the SPI bus.
   SPI.setBitOrder(MSBFIRST);
   SPI.setClockDivider(SPI_CLOCK_DIV16);
   SPI.setDataMode(SPI_MODE0);
    digitalWrite(CSPin, LOW);
    delay(10);
    byte1 = SPI.transfer(0);
    byte2 = SPI.transfer(0);
    delay(1);
    temp = byte1<<8;
    temp |= byte2;
    temp = temp >> 3;
    float temp2 = temp * 0.0625;
    Serial.println(temp, BIN);
    Serial.println(temp2);
    Serial.println("****");
    delay(2000);
And the output
10000100
8.25
10011001
9.56
11000010
12.13
11001000
12.50
110001111
24.94
11010000
13.00
110000001
24.06
11011001
13.56
What am I doing wrong
CT77 ?? What is that? datasheet?
The TC77 is a digital temperature sensor with SPI bus
temp can be INT ( signed 16 bits)
Convert to float BEFORE the division! (by 16.0)
as this SPI-interface use a single pin for I/O, try shiftIn
Here is my modifyed code
 int CSPin = 4;      //
 int MISOPin = 14;
 int SCKPin = 15;
 byte byte1;
 byte byte2;
 int temp;
  pinMode(SCKPin, OUTPUT);
  pinMode(MISOPin, INPUT);
    delay(1);
    byte1 = shiftIn(MISOPin, SCKPin, MSBFIRST);
    byte2 = shiftIn(MISOPin, SCKPin, MSBFIRST);
    delay(1);
    if(byte2 & 4){
    temp = byte1<<8;
    temp |= byte2;
    temp = temp >> 2;
    temp = temp >> 1;
    float temp2 = (float)temp * 0.0625;
    delay(2000);
And the output
10010010101
36.63
10001100001
35.00
10000110000
33.50
10000000001
32.00
10010000000
36.00
0
0.00
10010000000
36.00
0
0.00
10010000010
36.06
10001011
4.31
10010000000
36.00
1001
0.25
As described in the data sheet I can use Bit2 to test the conversion
4.2
Temperature Register (TEMP)
The Temperature register is read only and holds the
temperature conversion data. Bits 0 and 1 are unde-
fined and will be tri-state outputs during a read
sequence. Bit 2 is set to a logic ‘1’ after completion of
the first temperature conversion following a power-up
or reset event. Bit 2 is set to a logic ‘0’ during the time
needed to complete the first temperature conversion.
Therefore, the status of bit 2 can be monitored to indi-
cate that the TC77 has completed the first temperature
conversion.
If I do that
 if(byte2 & 4){
    temp = byte1<<8;
    temp |= byte2;
    temp = temp >> 2;
  temp = temp >> 1;
//    temp = byte2 & 0x04;
//    Serial.println(temp, BIN);
//    Serial.println("****");
    delay(2000);
And the output
10000011
4.06
10000001
4.00
10000001011
32.31
10001
0.50
10010010001
36.50
10000010001
32.50
10010010011
36.56
10001
0.50
10000000001
32.00
10000010011
32.56
10010010011
36.56
I can not understand why I do not get more reliable data
my best shot:
Negative temps OK (2’s compl)
int CSPin = 4;
int MISOPin = 14;
int SCKPin = 15;
byte byte1;
byte byte2;
int temp;
  pinMode(MISOPin, INPUT_PULLUP);
  // EDIT
  delay(350); // Allow sensor to do its 1.st reading after powerUp. (I guess this can be removed)
  delay(1); // EDIT: This may be removed ???
  // EDIT. Add:
  byte2 = byte2 & 0xF8; // mask away 3 bits. You dont need them
  temp = (int) byte1 << 8;
  temp |= byte2;
  float temp2 = (float)temp / 128; // EDIT equals >>3 and  * 0.0625;
  temp = temp >> 3; // Edit
  delay(2000);
If still trouble…: Make a while_loop.
Test ‘conversion_ready’-bit.
exit loop with the good values.
  do while (true)
      // EDIT. Add:
      if (byte2 & 4) break;
It's the best here until now
11111111111111111111011000010011
-158.81
1000010000
33.00
11111111111111111111100010000000
-120.00
1000010001
33.06
11111111111111111111011000000000
-160.00
1000010000
33.00
11111111111111111111101010010111
-86.56
1000010000
33.00
11111111111111111111011000011000
-158.50
1000010000
33.00
-158.50
1000010000
33.00
11111111111111111111011010010000
-151.00
1000010000
33.00
I think 33 degrees is too much.
I supply the sensor with 3.3v, but it should not mean anything.
If I make a sorting and removes the data that make no sense it looks sensible out
I had not seen your last code before now
 do
   // EDIT. Add:
    }while (true);
  temp |= byte2;
  delay(2000);
And the output
1000110011
35.19
1000100000
34.00
1000000011
32.19
1000100001
34.06
110001
3.06
10000
1.00
1000010010
33.13
10001
1.06
I'd like to see those signals on a scope..
It seems like you miss a single bit (value 32)
Noise ?? -> add a capacitor Ucc-Gnd close to sensor
from the Arduino reference:
If you're interfacing with a device that's clocked by rising edges, you'll need to make sure that the clock pin is low before the first call to shiftIn(), e.g. with a call to digitalWrite(clockPin, LOW).
That means: add a sentence in Setup
Hope you succeed..
Note the datasheet figures 2.6 and 2.7
Indicate you should use the correct Ucc for the sensor, (to get correct temp)
A 5V sensor @ 3v3 will be 'far off''
You are probably right with the noise problem.
We are creating a shield where we had problems with an analog temperature sensor (we use a stepup), so my CT77 sitting with wiring without external capacitor
I think my problems are solved with a new pcb with capacitor Ucc-Gnd and 5V suppy.
Many thanks for the help, you've been a great help.
