https://ctc101.arduino.cc/resources?id=32379590
me is not declared
What do I need to do to declare me? The code is not working.
me is not declared
You need to post the code here, because your link requires registration. Please read the forum instructions first, so you know how to use code tags for that.
clear() - turns all LEDs off.
on(LEDindex) - turns one LED on
off(LEDindex) - turns one LED off
scrollRight(speed, startIndex) - one LED light up at a time from left to right
scrollLeft(speed, startIndex) - one LED light up at a time from right to left
blink(LEDindex,speed, times) - one LED blinks
blinkAll(speed, times) - all LEDs blink
fillFrom(startIndex, stopIndex) - turns LEDs from startIndex to stopIndex on
fill(numberOfLEDs) - turns LEDs on from first to numberOfLEDs
#include <educationshield.h>
//Declare the VUMeter
VUMeter me;
//The pins used by the VUMeter, default to 2-5 and 7. Can be
//customized as wish, but do change the pinCount if the
//number of LEDs are changed.
int pins[]={2,3,4,5,7};
//How many pins are used. Should reflect the pins array above.
int pinCount=5;
void setup(){
//Configure the VU meter using parameters defined previously.
me.config(pinCount,pins);
//initialize the component. Must be called.
me.begin();
void loop(){
//fill(number)
// number: how many leds from first pin shall be turned on
//Fill 5 LEDs
me.fill(5);
delay(3000);
//clear()
//turn all the LEDs off
me.clear();
//on(index)
// index: which LED being turned on
//Turn the 3rd LED on
me.on(2);
//off(index)
// index: which LED being turned off
//Turn the 3rd LED off
me.off(2);
//scrollRight(speed, startIndex)
// speed: milliseconds before the next LED turns on
// startIndex: from which LED to the left it start
// scrolling. If not specified, it's 1.
//One LED light up at a time, scroll from left to right
me.scrollRight(700);
//scrollLeft(speed, startIndex)
// startIndex: from which LED TO THE RIGHT it start
//And then scroll back from the 2nd on the right
me.scrollLeft(700,1);
//blink(index, speed, times)
// index: which LED should blink
// speed: milliseconds, of which the LED light on and off
// times: how many times the LED blinks. Defaults to 1
//the 3rd led will be blinking for 10 times, each time
//with 100 milliseconds on and 100 milliseconds off
me.blink(2,100,10);
//blinkAll(speed, times)
// speed: milliseconds, of which all LEDs light on and off
//All LEDs will be blinking 10 times
me.blinkAll(100,10);
//fillFrom(leftIndex,rightIndex)
// leftIndex: start filling from which LED
// rightIndex: end filling to which LED
//The 2nd to 4th LED will be light up
me.fillFrom(1,3);
delay(2000);
}</educationshield.h>
I did mention the code tags! Please follow the program and add them! I did forget to ask for the complete compile error listing, a 3 word quotation is not enough.
It says: 'VUMeter' does not name a type
Please read. I asked for the complete compiler error listing and code tags.
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
sketch_feb14a:21:10: fatal error: educationshield.h: No such file or directory
compilation terminated.
exit status 1
option enabled in File -> Preferences.
//When I delete educationshield.h, it says:
sketch_feb14a:24:1: error: 'VUMeter' does not name a type
VUMeter me;
C:\Users\kristen_roecker1\Documents\Arduino\sketch_feb14a\sketch_feb14a.ino: In function 'void setup()':
sketch_feb14a:36:3: error: 'me' was not declared in this scope
C:\Users\kristen_roecker1\Documents\Arduino\sketch_feb14a\sketch_feb14a.ino: In function 'void loop()':
sketch_feb14a:47:3: error: 'me' was not declared in this scope
me.fill(5);
C:\Users\kristen_roecker1\Documents\Arduino\sketch_feb14a\sketch_feb14a.ino: At global scope:
sketch_feb14a:110:2: error: expected unqualified-id before '<' token
exit status 1
That's telling you that you are missing that library.
Crucial it is.
https://github.com/arduino-libraries/EducationShield/
Why do I need the library? Why can't I just run the code? How do I connect my code to the library? Why isn't this explained in CTC 101? What do I need to do?
Looks like the code is not running without
Because the library is needed
It is already is "connected" by #include <educationshield.h>
Ask the author of CTC101, or just skip that question.
Ask more meaningful questions; and read the answers of the others carefully.
Download the library from the link provided or use the arduino library manager and search for it (educationshield .h)
post edit --
adding pic
I think there is a "getting started with Arduino" on this site, it answers a lot of your questions.
There certainly is an explanation of how to ask questions!
A library is pre-written code so you don't have to write everything yourself or you don't have to write (or copy) the same code over-and-over. (It makes your code "look simpler".)
I don't know anything about that library but if you were making a VU meter library you might want to make a function that calculates dB and you could put that function in a library. Of course, when you call that function you program would need access to that library.
Thank you!
