CTC and ADC autotrigger
Is it possible to use an interrupt from TIMER1_COMPA_vect as an autotrigger source for ADC conversion?
According to the spec, it appears that only COMPB can be used to auto trigger the ADC. Am I missing something?
If the autotrigger isn't possible, I can manually trigger a conversion I guess.
I am using UNO btw
memotick: Is it possible to use an interrupt from TIMER1_COMPA_vect as an autotrigger source for ADC conversion?
Doesn't look like it.
As long as your application can tolerate the latency.
Run two channel in parallel, loading same value to A and B. In this case channel A keep frequency , and B triggers ADC . Click on a link below, I used this technics in a few latest blogs, there is a code for UNO.
