CubeCell AB02A with HTU21D
Hello everybody,
I'm trying to connect a HTU21D sensor to a CubeCell AB02A, I'm using the example sketch of the Arduino library specific for the AB02A and it's not working, it gives back t° -46.8 and Humidity -6%.
Here it is the sketch
 HTU21D Humidity Sensor Example Code
 By: Nathan Seidle
 SparkFun Electronics
 Date: September 15th, 2013
 License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
 Uses the HTU21D library to display the current humidity and temperature
  Adapted to CubeCell HTCC-AB01 by Mike Cochrane
  December 31, 2019
  Hardware Connections:
   CubeCell Pin  HTU21D Board       Function
   Vext          VCC                Power
   GND           GND                Ground
   SDA           SDA                I2C Data
   SCL           SCL                I2C Clock
#include <Wire.h>
#include "SparkFunHTU21D.h"
//Create an instance of the object
HTU21D myHumidity;
    pinMode(Vext, OUTPUT);
    Serial.println("HTU21D Example!");
    // Vext ON
    digitalWrite(Vext, LOW);
    delay(50);
    myHumidity.begin();
    float humd = myHumidity.readHumidity();
    float temp = myHumidity.readTemperature();
    Wire.end();
    // Vext OFF
    digitalWrite(Vext, HIGH);
    Serial.print("Temperature: ");
    if (temp == ERROR_I2C_TIMEOUT) {
      Serial.print("i2c timeout");
    } else if (temp == ERROR_BAD_CRC) {
      Serial.print("bad crc");
      Serial.print(temp, 1);
      Serial.print("C");
    Serial.print(" Humidity: ");
    Serial.print(humd, 1);
    Serial.println("%");
Thank you for your help!
