Cubing an int16
Playing with some 12bit ADCs and I'd like to experiment with some linearisation functions involving squares/cubes.
I want to scan these ADCs as fast as possible, so trying to avoid floats.
X^2 is fine because max value for 12bit signed is 2048, which means it's square can only reach 4,194,304 and that fit's into an int32_t. No problem there.
But a X^3 could be 8,589,934,592 which could blow out an int32.
The linearisation functions usually finish off with a division, and if I move that to the other side, this can help ...e.g
int16_t x; // 12bit input
int16_t n = x / 16;
int32_t y = n * n * n;
..but this results in a substantial loss of precision.
Also I was sticking with multiplication as I've read it can be 10 times faster than Math.pow().
How is this situation normally handled efficiently?
uint64_t ?
Which CPU?
int64 is pretty slow on an AVR.
Feeling stupid now I didn't realise we had 64bit ints to play with!
Messing with ESP32 at the minute. I guess it can probably handle int64_t just fine. \Better than a float anyways.
if you do that the right side of the assignment n * n * n is calculated using int16_t (so with overflow) and only then converted in a 32 bit value. so it won't work unless you cast the values for the multiplication (at least the first one) to int32_t
if you divide first before taking the cube you need to divide by the cubic root . was the divisor 4096 and that's why you used 16?
say x = 16n + r when you divide by 16 you only get n and looses the r ➜ as the early division is also conducted in integral numbers you loose part of the decimals raised to the cube.
but if you know you have to take r into account
x3 / 4096 = (x/16)3 = ((16n + r)/16)3 = (n + r/16)3
now it's just a matter of developing this into separate factors
(a + b)3 = a3 + 3a2b + 3ab2 + b3
so you get
n3 + 3n2r/16 + 3nr2/256 + r3/4096
the part 3n2r/16 + 3nr2/256 + r3/4096 is your approximation error (and you could calculate that fast enough, dividing by 16, 256 or 4096 are simple bit shifts)
