CuHead Wifi dropping requests
I'm using the Arduino Uno with CuHead wifi shield and the user contributed library from asynclabs.. GitHub - asynclabs/WiShield_user_contrib: WiShield library with user contributed features
I've had to update the library to IDE v1.0 and am basing my code off the SimpleClient example.
Problem #1:
The Arduino setup is randomly dropping my GET requests to my server.
Question: Any ideas what could be causing this or where should I be investigating?
Symptoms:
  • Typically the first request is dropped
  • Sometimes it takes multiple tries before one makes it and then it's fine.
  • When you stop sending requests for a few minutes and then start again without turning off the Arduino, the first one or two will get dropped.
Setup:
I've had the Arduino be 6 inches to 30ft away from the router. I've tried 4 different routers. When I do a ping to the server from my laptop, the connection is there and the response time is 90-120ms.
Problem #2:
The response time from the server varies... some times its almost instant and other times it literally takes a good 5-10 secs!
Question: Any theories as to why? Any way to resolve this?
Thanks,
Hiren.
