CuHead WiFi Shield for Arduino V2.0 on Arduino Uno R3
Please help with CuHead WiFi Shield for Arduino V2.0 on Arduino Uno R3, I just bought this CuHead 2.0, plug it on Uno R3, load example from ZG2100BasedWiFiShield-master but error when try to compile it :
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:32:18: error: nvic.h: No such file or directory
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:33:18: error: exti.h: No such file or directory
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:34:20: error: wirish.h: No such file or directory
In file included from D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:35:
D:\My Documents\Arduino\libraries\WiShield/maple-spi.h:91: error: expected '=', ',', ';', 'asm' or 'attribute' before 'zg_spi_tx_byte'
D:\My Documents\Arduino\libraries\WiShield/maple-spi.h:102: error: expected ')' before 'channel'
In file included from D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:36:
D:\My Documents\Arduino\libraries\WiShield/maple-util.h:18: error: expected ')' before 'ch'
D:\My Documents\Arduino\libraries\WiShield/maple-util.h:20: error: expected declaration specifiers or '...' before 'uint32'
D:\My Documents\Arduino\libraries\WiShield/maple-util.h:21: error: expected '=', ',', ';', 'asm' or 'attribute' before 'serialUsbReadBuf'
D:\My Documents\Arduino\libraries\WiShield/maple-util.h:22: error: expected '=', ',', ';', 'asm' or 'attribute' before 'serialUsbRead'
D:\My Documents\Arduino\libraries\WiShield/maple-util.h:23: error: expected '=', ',', ';', 'asm' or 'attribute' before 'serialUsbIsConnected'
D:\My Documents\Arduino\libraries\WiShield/maple-util.h:32: error: expected ')' before 'byte'
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:47: error: expected ')' before 'channel'
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:84: error: expected ')' before 'channel'
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:101: error: expected '=', ',', ';', 'asm' or 'attribute' before 'prescaleFactors'
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c: In function 'SPI1_Init':
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:114: error: 'uint32' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:114: error: (Each undeclared identifier is reported only once
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:114: error: for each function it appears in.)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:114: error: expected ';' before 'spi_num'
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:120: error: 'OUTPUT' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:123: error: 'D2' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:123: error: 'INPUT' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:126: error: 'spi_num' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:127: error: 'endian' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:127: error: 'SPI_MSBFIRST' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:130: error: 'prescale' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:130: error: 'prescaleFactors' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:131: error: 'mode' undeclared (first use in this function)
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c: At top level:
D:\My Documents\Arduino\libraries\WiShield\maple-spi.c:143: error: expected '=', ',', ';', 'asm' or 'attribute' before 'zg_spi_tx_byte'
note :
  1. Iam using Arduino 1.5.6-r2, and already try WiShield-master from linksprite.com without an expected result,
  2. result from wifi library : WiFi shield not present
thanks in advance
Which part of this message do you not understand?
thank's for quick response...
I where i can get those files cause i can't find in ZG2100BasedWiFiShield-master packet, maybe i should googling first...
thanks again
Finally I got it connected with simple server sample ...
anyone that still struggle with CuHead WiFi Shield for Arduino V2.0 on Arduino Uno R3 to make it work maybe wanna try :
  1. using arduino IDE .22
  2. wiserver from nicolaskruchten (you can download at github)..
that's all
