Fuel control is very close to my current project. I am in the process of attaching two linear actuators for marine engine upgrades. one throttle, second is gear. demand value is input from CAN bus. Older engines can be upgraded by such actuators to behave like recent engine designs, which are controlled only by CAN bus set values.
I made a lot of research for actuators, which fit the criteria and can say the linear actuators you posted are not suitable for anything close to your needs. You should not underestimate the precision you need for repetitive results. With a flummy drive like those you will have a headache to determine your position and it will require quite a job to get a closed loop position regulation with satisfactory results.
our force requirements are higher for the gearbox, we want 200N @ 100mm/sec travel speed to have a true proportional movement.
And of course it need to be linear without lots of mechanical gizmos.
I found these are definetly perfect: Nanotec - Precise and Reliable Motion Control Solutions it has only 40N but is really compact. It is not flummy, and the stepper allows you to have a repetitive positioning without a closed loop regulation.
mechanically I added a control cable which is common in marine applications they allow gap free push-pull movement and is easily attached in line to the linear spindle, the other end of the rod is mounted to the throttle lever by a standard junction.
The connection of the spindle and that rod is the only mechanical add on you need with this setup.
I of course have enclosed the whole mechanics in a robust waterproof box.
it is a very strong stepper for the size, but gives a linear move at surprising high speed, low gap and perfect repetition if you do not loose steps by blocked route. all you need is a zero position sensor, so you need your position at startup. I use a contactless sensor (Hall switch) to have absolutely no moving parts or stuff which can get defect. it is mechanically also much simpler to mount than any other mechanical switch, and it has de-facto unlimited lifespan.
a tiny magnet at the end of the spindle will trigger the hall switch, tell the digital input when the zero position is reached.
the stepper can be controlled by the arudino library, the only thing you need is a power H-bridge with some diodes to drive the 1Amp bipolar (it is a 4 wire motor).
I am pretty happy about the outcome so far with this setup, and add a professional stepper driver (http://www.onsemi.com/pub_link/Collateral/AMIS-30542-D.PDF) to it which hopefully can tell me lost steps and mechanical blockings to get ultimate robust application.
all in all this is a very professional setup by simple tools, I am impressed about the simplicity prototyping works in the arudino world.
The linear axis is below $100, and compared with the power and precision I could not find anything close to that.
well, the window movers are cheaper - but a waste of time. the servos from model airplanes are better, but mechanically not a robust thing as well I would fear the "mechanical setup".
