Cuomo: Nat'l Guard will be employed to squeeze AMBU-Bags as Ventilators
At noon today on Fox News Governor Cuomo explained if they don't have ventilators they will train National Guard soldiers to squeeze BVMs.
Fox News: Governor Cuomo holds daily coronavirus press conference – BVM topic - VIDEO
Fox News: Governor Cuomo holds daily coronavirus press conference – BVM topic - SCREENSHOT
C'MON PEOPLE The Nat'l Guard has better things to do !!!! Automate this!!!!!
YOU NEED TO CONTACT THE FDA FIRST TO FIND OUT WHAT THEY MAY ULTIMATELY ALLOW IN HOSPITALS
OXYGEN CAN BE VERY DANGEROUS IT CAN DEGRADE MATERIALS, CAUSE FIRES or EXPLOSIONS. TOO MUCH OXYGEN OR CO2 CAN CAUSE LUNG INFLAMMATION AND DEATH.
CONTACT U of M BECAUSE THEY ALREADY HAVE A DESIGN IN PARTNERSHIP WITH DIGIKEY.
U of M COVID-19 Ventilator[/b]
Cuomo is an idiot so let's get that out of the way first.
Years ago we provided home health care for my mother in law. As her conditions deteriorated more and more devices came into the house and her room. The ventilator was among things connected to a tracheotomy tube. The difference between a ventilator and for example a respirator is pretty much that a vent machine thinks. When a patient can and is breathing on their own the machine just mild assist and if the patient can't breathe the machine does it for them. The amount the machine assist is rated in a percentage.
Anyway as assorted things came in I am looking at the electric needs and thinking while most of this stuff has batteries the backup time is short lived. The vent had an internal 12 volt battery good for 20 min. Then you "bag" the patient and good luck with that. Bagging means you hold a bag and squeeze over and over again, breath after breath. After about 5 min of that every muscle in your hand is screaming for mercy. Cuomo has no clue what any of this is about or what is involved. I bought a generator and have had backup power ever since.
Actually the idea of vent machines was addressed years ago but sadly for assorted reasons never took off. They were planned for just a pandemic as we have now. Train the National Guard to bag a patient?
Ron
A few of these devices are actually starting to be produced. Please see:
Public Inventor COVID-19 Ventilator Projects and Resources and FAQ
for a list that shows the current status and evaluation of at least 31 projects.
If you have enough soldiers you could keep people alive. But each soldier needs PPE, and a respirator.
Ron_Blain:
Cuomo clearly states this exactly.
...someone squeezes the ventilator, the bag, continuously. This looks easy. I guarantee if you do this for any length of time you see how difficult it winds up being. ... You need a lot of people to operate this 24 hours a day for each patient. ... Short answer is, no thank you.
Now, I have a question here, does Bagging solve our issue in case of corona virus.
I just talked to a medical student who said we use bagging in cases where the case is not too critical.
Can someone guide me here, only if I come to know that bagging will solve our problem to large extent,then I am down for the job
Thanks for your efforts
Also, in case of Ambu bagging, isn't this important as to how would you put the mask on the face of the patient
I mean, isn't that a bigger issue than just pumping, or is there any other design which solves this problem.If not, can we automate that part??????????
@sabishaw
You have to go through some of the other posts where this automation is being discussed.
Some clever ideas coming out from people.
Bob.
OK, Politics is #1 for you, so let's get that out of the way first.
Antes de hacer nada con Arduino, asegúrese de que se puede homologar en su país, en España, ya ha habido varias iniciativas que no se han podido llevar a cabo por los problemas de homologación, se han hecho respiradores, pantallas de protección, y un sinfín de productos que en un principio se pueden utilizar para ayudar en esta emergencia, pero sin embargo cuando se ha intentado entregar, lo primero que se ha pedido es el certificado de homologación, y el certificado de poder utilizarse en la Unión Europea, sin estos documentos, todo el esfuerzo en hacer el proyecto, ha ido directamente a la basura, ( o por lo menos eso han dicho), porque se quedan con el material, requisado, para que no se pueda vender.
Por ejemplo, en España, ha habido un grupo de personas que tenían impresoras 3D, y se han puesto a imprimir pantallas de protección, han conseguido 5.000 unidades en una semana, las han levado a un Hospital de Madrid, y las han rechazado, por no estar homologadas.
En este momento, solo las empresas autorizadas por los distintos gobiernos, son las que únicamente pueden hacer este tipo de productos, por ejemplo General Motors, en Estados Unidos, SEAT, en España, y siempre después de pasar los controles de homologación.
La intención es buena, pero en la mayoría de los casos, está condenada al fracaso por la burocracia de los distintos países, y los distintos intereses económicos alrededor de ese producto.
Tenga en cuenta que cada respirador que se utiliza en una Unidad de Cuidados Intensivos UCI, vale en el mercado entre 25.000 y 30.000 Euros, al cambio entre más o menos 24.000 y 29.000 Dólares USA, cuando el coste real con motores reutilizados y Arduino, no llega a los 200 € ninguno de los proyectos que se han construido en casa, con toda la buena intención, los dejan utilizar en los hospitales, por lo menos en Europa
Before doing anything with Arduino, make sure that it can be approved in your country, in Spain, there have already been several initiatives that have not been carried out by the problems of type-approval, have become respirators, screens of protection, and a host of products that in a principle can be used to assist in this emergency, but however when attempted to deliver, the first thing that has been requested is the approval certificate, and the certificate of being able to be used in the European Union, without these documents, all the effort in doing the project, it has gone straight to the trash, (or at least that's what they've said), because they keep the material, requisitioned, so that it can't be sold.
For example, in Spain, there has been a group of people who had 3D printers, and they have started printing screens of protection, they have obtained 5,000 units in a week, taken them to a Hospital in Madrid, and rejected them, because they were not approved.
At this time, only companies authorized by the different governments, are those that can only make this type of products, for example General Motors, in the United States, SEAT, in Spain, and always after passing the approval checks.
The intention is good, but in most cases, it is doomed to failure by the bureaucracy of the different countries, and the different economic interests around that product.
Please note that each respirator that is used in an ICU Intensive Care Unit, is valid on the market between 25,000 and 30,000 Euros, when the change between about 24,000 and 29,000 US Dollars, when the actual cost with repurposed engines and Arduino, does not reach 200 none of the projects that have been built at home, with all the good intentions, let them use them in hospitals, at least in Europe
