CurieBLE disconnect after sending Notifications
Hello everybody,
I'm just trying to send messages from the Arduino to an Android client via BLE. For this I use the library CurieBLE version 2.0.
To send as many packages as possible, I use notifications. The goal is to generate as much throughput as possible. However, the Arduino always disconnected after a few notifications, if the connection interval is greater than 12. What can be the reason and which class is responsible for the dissconnect?
The code:
BLEFloatCharacteristic valueCharacteristic("19B10000-E8F2-537E-4F6C-D104768A1216", BLERead | BLENotify);
         while ((endtime - starttime) <= 5000) // do this loop for up to 1000mS
            float sensorValue  = analogRead(A0); //float = 4 byte
            boolean succes = valueCharacteristic.setValue(sensorValue);
            endtime = millis();
Hi @chrispy15
Please open an issue on Github and include a minimal sketch that can be used to reproduce the issue. Along with steps to trigger the issue.
For those wanting to follow on, the Github issue can be found here disconnect after sending Notifications · Issue #545 · arduino/ArduinoCore-arc32 · GitHub
