CurieBLE Reference
Hello,
I'm confused about something related to the CurieBLE library that I hope someone can help me clear up.
I am using some example code I found on the web to begin a project of my own, using the CurieBLE library. Some of the library calls in the sample code are referencing functions that I don't see in the CurieBLE reference page (https://www.arduino.cc/en/Reference/CurieBLE).
For example, these snippets from the sample code (which by the way, compiles and runs on my Arduino 101):
BLE.scan();
if (peripheral.localName()=="PowerLight") {
BLE.stopScan();
BLE.scanForUuid("19B10000-E8F2-537E-4F6C-D104768A1214");
The above calls do not exist in the CurieBLE reference on Arduino's website, at least not that I have been able to locate.
Can someone help?
Thanks...Doug
Yes, that's unfortunate that the documentation is incomplete. Luckily there is some documentation in the source code.
BLE.scan():
     * @brief   Start scanning for peripherals with the option of accepting all detectable
     *          Peripherals or just the newly detected.
     * @param[in] withDuplicates        true - return all detectable Peripherals.
     *                                  false- return a detected Peripheral only once.
     * @return  none
     * @note  When, withDuplicates = true, accept all detectable Peripherals.
     *        No Peripheral filtering process applied to the scan result.
     *        By default, withDuplicates = false, a detected Peripheral is
     *        reported once.
void scan(bool withDuplicates = false);
localName():
   String localName() const; // returns the advertised local name as a String
BLE.stopScan():
     * @brief   Stop scanning for peripherals
     * @param   none
     * @return  none
     * @note  none
    void stopScan();
BLE.scanForUuid():
     * @brief   Start scanning for peripherals and filter by service in ADV and
     *          the option of accepting all detectable Peripherals or just the
     *          newly detected.
     * @param[in]   service    The service
     * @return  none
     *         reported once.
     void scanForUuid(String uuid, bool withDuplicates = false);
I have reported this issue to the Arduino developers at Not all CurieBLE library functions are documented · Issue #6739 · arduino/Arduino · GitHub
Thanks for reporting this rdprecure!
Thanks a bunch pert, that helps. I didn't think to look deeper into some of the other includes.
