Curl command with integer data
So I have some sensors which I would like to connect to a php script I and stores the GET data as variables.
I can curl to the script by hardcoding the values iecurl http://website.com/Update.php?value1=data
but when I try using curl http://website.com/Update.php?value1="+dataVariable+"
it produces an error complaing that the int data has to be converted to a string...
so I do the same thing but I wrap the variable in String(dataVariable) and it works although the variable now uploads as 0 each time.
I'm storing the data as an int on both my database and on the arduino sketch .. it is holding data from 100 - 15000 so I assume an int is ok to hold it (it works fine when I send it to the Console to view but just wont upload well)
I don't see that your problem has anything to do with the Arduino.
I don't see that it has anything to do with curl, either.
Of course, the good folks at http://snippets-r-us.com might be able to help you with your snippets. They make no sense to me.
Well I want to use Curl and I also want to use my Arduino so I figured posting on the Arduino forum would be sensible.
I'm asking how can I curl a variable into a link to a script.
And, I'm asking what the hell this even means. A variable is a memory location that holds a value. Is the memory location in question on the Arduino? If so, then you can't use the contents of that memory location in a call to a function that runs on the PC.
If not, just where does that memory location live?
I have already said I have a php script that takes GET data ... so if I go to the link website.com/Update.php?value=10
the script will take the value of 10 and store it in a database. I don't want to have a hardcoded value of 10 but instead a variable of x that I can change.
So instead of doing curl website.com/Update.php?value=10 id like to do curl website.com/Update.php?value=x
Where X can be anything.
Now I have seen this done with the example of uploading data to a google spreadsheet so I know it can be done, the issue here is when I use my variable which is an int .. it gives an error that it should be a string. When I convert to string the value = 0
and if you're getting confused, the arduino yun can use curl ... I'm not trying to use it on a pc.
You could use sprintf
Example
Make a char array called buffer
char buffer[50];
your value is 17
int val=17
sprintf (buffer, “http://website.com/Update.php?value1=%d”, val);
now you can use Curl
Curl buffer
Below is a test sketch I made, just to test my database
  Running process using Process class.
 This sketch demonstrate how to run linux processes
 using an Arduino Yún.
 created 5 Jun 2013
 by Cristian Maglie
 This example code is in the public domain.
 http://arduino.cc/en/Tutorial/Process
#include <Process.h>
char buffer[50];
int val=1200;
  // Initialize Bridge
  Bridge.begin();
  // Initialize Serial
  // Wait until a Serial Monitor is connected.
  while (!Serial);
  // run various example processes
  //runCurl(val);
  //runCpuInfo();
  Serial.println("Starting");
  sprintf (buffer, "arduino.local/sd/test/upd_testdb.php?tekst=%d", val);
   val++;
   Serial.println(buffer);
   runCurl();
   delay(10000);
  // Do nothing here.
void runCurl() {
  // curl is command line program for transferring data using different internet protocols
  Process p;		// Create a process and call it "p"
  p.begin("curl");	// Process that launch the "curl" command
  p.addParameter(buffer); // Add the URL parameter to "curl"
  p.run();		// Run the process and wait for its termination
  // A process output can be read with the stream methods
  while (p.available()>0) {
    char c = p.read();
    Serial.print(c);
  // Ensure the last bit of data is sent.
  Serial.flush();
Then, why the f**k aren't you posting in the Yun section of the forum? And, where the hell is your code, so your question even makes sense?
