CURL / SSL
Heij :slight_smile: ,
I have some troubles with the YÚN Bridge and a process.
I want to send push-notifications over the "Pushover-Service".
To send a mess I need to connect via CURL.
So I tried to send the push-notification over the Linino-Consol. I just typed in the following and it worked wonderfully:
curl -S \-F "token=MYTOKEN" \-F "user=MYUSER" \-F "message=hello world"  \http://api.pushover.net/1/messages.json
Even if want to connect over SSL, it worked wonderfull (I just have to add -k because of certification)
curl -S \-F "token=MYTOKEN" \-F "user=MYUSER" \-F "message=hello world" \-k  \https://api.pushover.net/1/messages.json
But then I want to apply the same over the Bridge:
#include <Process.h>
  // Initialize Bridge
  Bridge.begin();
  // Initialize Serial
  // Wait until a Serial Monitor is connected.
  while (!Serial);
  // Launch "curl" command
  Process p;             // Create a process and call it "p"
  p.begin("curl");       // launch the "curl" command
  p.addParameter("-S");   // Add a parameter
  p.addParameter("\\-F \"token=MYTOKEN\""); // Add a parameter
  p.addParameter("\\-F \"user=MYUSER\""); // Add a parameter
  p.addParameter("\\-F \"message=hello\"");                       // Add a parameter
  p.addParameter("http://api.pushover.net/1/messages.json");     // Add the URL parameter
  p.run();      // Run the process and wait for its termination
  //Send the requested data to the seriell monitor
  while (p.available() > 0) {
    char c = p.read();
    Serial.print(c);
  // Ensure the last bit of data is sent.
  Serial.flush();
The server requested, that he want a connection over SSL. OK, I don't know why he need it now (over the console he did not need it), but if he want so...
I changed the URL to
 p.addParameter("https://api.pushover.net/1/messages.json");     // Add the URL parameter
and add the parameter
 p.addParameter("\\-k");
From now on, the server did not give me any answers. Just nothing happen.
Can anyone find my mistake?
Thanks in advance. (Sorry for my bad english :cold_sweat: )
waelder
