current detector with led power on
Hi to all !
I have this 3 pole filter in my receiver’s last stage. I want to put a led, so when the current is passing through my circuit the led will light on. I need this because my transmitter a lot of time, don’t work fine, so i don’t know if there any signal going to my receiver.
It is a way to check it.
Any ideas for cheap consuption ?http://i1284.photobucket.com/albums/a578/fovos1/Circuit_zpsb91f9e29.png
Current passing through a wire creates a magnetic field. You can measure it with something like this:
http://www.ebay.com/sch/i.html?_nkw=current+sensor+module
Thanks for your help! But, this is so huge for my devices. I need some electronics schematic //maybe with some BJT/FET some resistors and a led
Fovakis: Thanks for your help! But, this is so huge for my devices. I need some electronics schematic //maybe with some BJT/FET some resistors and a led
In that case you probably want something like this where you pass your wire through it:
http://www.ebay.com/itm/230991057211
That's is so cool man!! really! but i believe i can do it more simply :stuck_out_tongue_closed_eyes:
Fovakis:
That’s is so cool man!! really! but i believe i can do it more simply :stuck_out_tongue_closed_eyes:
You might need a different diameter/rating … but simpler than that? :~
yes it is simple.but is cost more that some led and bjt and also it need some weeks to come to my country (Greece). I need to prepare something at this week bro :~ 8)
Fovakis: yes it is simple.but is cost more that some led and bjt and also it need some weeks to come to my country (Greece). I need to prepare something at this week bro :~ 8)
If all you need is on/off (not measure accurate values) then maybe you can just wrap a coil of wire around your cable. Ground one end, measure the voltage on the other end. That's basically all those sensors are.
nb. Be sure to put a resistor between the coil and the Arduino pin.
How many turns is needed?
tocpcs: How many turns is needed?
Depends on the strength of your magnetic field.
You give no details about the transmitter, but you might try a neon bulb. Just connect it to the output with a series resistor. If the RF gets above 50V it will light. a simple high impedance detector probe might work, too.
