Current sense prob !!!
I am using 5A current sensor using Lm358 op-amp so far i tested with 60w bulb the output is 1.31v dc..
how to calculate actual current
example for ACS714 Current Sensor Board:
sensorValue = analogRead(analogInPin);
// convert to milli amps
outputValue = (((long)sensorValue * 5000 / 1024) - 500 ) * 1000 / 133;
amps = (float) outputValue / 1000;
this is the code for ACS714 Current Sensor Board:
But how to write a code for lm356Ic ?? can u help me ??
shyamvenkat:
can u help me ??
dunno. can u write a better question and explain what the issue is?
shyamvenkat:
You need to know the formula for the conversion, and then implement it in code. We can help with the second part if you get stuck; the first part is up to you.
