Current sensing resistors, are they special?
The reference circuit for my stepper driver requires 0.3ohm resistors to sense the current. On Farnell, they have a special category of current sensing resistors and they are relatively expensive, but on RS they do not have a special category. Can I use any 0.3ohm resistor, providing it is rated above the wattage it will dissipate? I can get a pack of 10 SMD's for less than the cost of one through hole package.
The high priced ones are probably low inductance / high precision resistors, that you would need to use to accurately measure short pulses of current (sub microsecond).
However if you only want an indication of the current drawn by the stepper over a period of milliseconds or more, then the cheaper ones will probably surfice
Current sense resistor is often just a resistor. Some are 4-terminal though, and a 4-terminal resistor is
different. The inductance of wire-wound resistors could be a problem in some applications. Surface mount
resistors are never to my knowledge inductive.
Google "4-terminal resistor" and "Kelvin measurement"
Current sense resistors are often spec'ed for greater accuracy than normal ones (they're often 1% resistors, for example). Consult the datasheets of the specific components and compare the specs - you'll find differences between ones intended for current sensing applications.
1% is pretty normal for surface mount resistors these days!
I think they are sometimes listed as 'thickfilm'.
Use 4x 1.2ohm in parallel for higher currents.
Leo..
It really could be any resistor of the appropriate wattage. But why skimp on an important part? This is critical to the correct operation of the stepper driver, so I would choose the specialised resistor.
If you had 10,000 LEDs needing dropper resistors, then saving a few cents on the resistors might be justified.
After investigating the data sheet for the SMD resistors, they are recommended for current sensing. These cost me £1.50 for 10 with free delivery, rather than having to spend £3 each plus £15 delivery. It's not about saving a few cents, but I do see your point. Now it's a case of practising soldering them and finding the right foot prints in ultiboard :slight_smile:
Jesus christ, $1.50/10 (more like 20 cents each, I think, pound sterling is bigger than the almighty Dollar) is already in what I'd consider high for resistors.
A $3+ resistor had better be a damned fancy resistor. That's just crazy price for a resistor.
DrAzzy:
Do you perhaps mean **0.**1%?
Presumably purposed for accurate metering.
Well the ones I am considering buying are 5%, the data sheet states they are suitable for current sensing. I can see that they would be no good for accurate metering, but in this case I think they would suffice? (That is if I understand what has been discussed in this thread correctly.) Of course, if I can locate some 1% resistors at 5W for a decent price I will go for those.
DrAzzy:
When I was at school 1.50 divided by 10 was 0.15 or 15 cents in dollar terms, so your 20 cent resistors are somewhat over-priced.
DrAzzy:
I use a bit of nichrome wire for LA battery monitoring.
But i do have the ability to borrow a NIST traceable resisrance meter.
If you trust the wire specs its possible to get accurate results providing you use screw clamps for the termination method.
At one time we used to use the the nichrome wire from open bar electric fires for rough 'n ready low value resistors. Happy days
jackrae:
I suspect you can still get jug elements.
WHAT stepper driver ?
L6208
Are you making your own PCB ?
How much did pay for the driver ?
Yes, I am making the PCB. I need to learn multisim and ultiboard over the summer and figured this would be a good project to get to grips with the software. I have used Eagle to make simpler boards such as PWM LED controllers and have been etching them at home. The driver chips I got as free samples from ST, I have three of them.
As we are discussing the PCB, from what I have looked at, these current sensing resistors need to be as close to the chip as possible, terminating on the ground plane? Also, each chip will need it's own decoupling capacitors as close to the chip as possible?
