I have the LD1255 Laser Driver and wanted to monitor it using an Arduino.
https://www.thorlabs.com/thorcat/0000/LD1255-Manual.pdf
Looking through the manual, I find that I can monitor the current using J1-10 pin.
The problem I run into is that there is a 2nd signal that I must connect and it is not a ground reference.
J1-10 and J2-4 must be connected to get this to work. (Page 3)
I can connect J1-10 to monitor the current to ANALOG IN, but where do I attach J2-4? (Do I connect it to the GND?)
