My question is: Why are there are two pins for IP+ and two pins for IP- ?
One is large and one is small. After reading several articles online it seems like you need to connect your load in series with this sensor using the IP+ and IP- pins. But why is there two of each?
I would imagine that it is for a current shunt in case you wanted to measure a higher range of currents, although there is nothing to support this theory in the data sheet.
Thanks for the replies guys! You are probably correct about them being alternate mounting locations.
I will do a continuity check to prove that theory.
