Current sensing
Making an E-bike. I want to find out how much current the motor is sucking up. Does anyone know of any good induction sensors?
I'd recommend a Hall effect sensor like these:
http://www.allegromicro.com/en/Products/Categories/Sensors/currentsensor.asp
The Quick Shield: breakout all 28 pins to quick-connect terminals
Thanks for that link. I like those, but I don't quite understand the Measurement Range on them. If it says ±5 to 30, are we saying it can handle plus or minus 5 to 30 amps? So below 5 amps I'd not really be able to measure anything?
And another thing I was thinking as I looked at a really beefy (90 amp) one on SparkFun called the AttoPilot that says it measures in increments of 36.60mV per amp. I have been busy and don't have much time to test, does anyone know how precisely the duemilanove can read a voltage?
Yes that's right, the signal will be so low it will be lost in the noise.
With a 5V reference voltage each step is 5/ 1023 = 4.88 mV per step.
If you switch to the internal 1v1 reference this becomes:- 1.1 / 1023 = 1.075mV per step.
Bear in mind that you can increase the maximum range of these sensors by using a shunt. Of course this will be at the expense of resolution. They're also pretty jumpy when sensing current consumption of a motor. This can be solved in software or by increasing the size of the filter cap.
you might consider using one of these.
http://www.diodes.com.tw/zetex/_pdfs/3.0/pdf/ZXCT1009.pdf
Good call, that may help me. Not sure yet how much current my motor will draw, but I'll bet a shunt may come in handy later on. Thanks.
EDIT: Wait hold on - I've been looking around because honestly I didn't know what you meant by a shunt. I found some stuff, but need to make sure I know what I'm talking about. Are we saying that I can throw something in series with the device that senses current so as to draw some of the current and not exceed the max current rating of the device?
I read on Wikipedia about throwing a precision resistor in series with the load and measuring voltage off of that and do some math to get my current, but I don't think I could find a resistor that could handle 30+ amps...
Just a matter of searching around. They can sometimes be found in surplus outfits or at good prices on E-bay.
Lefty
A resistor used in that way is called a shunt.
I'd like to emphasize the "of these sensors" part. I can see the logic behind measuring the voltage drop of the resistor, but what's daveg talking about? wire in a shunt and the sensor somehow together....?
He is talking about the sensors mentioned in reply #1.
You can get it to read higher currents if you bypass some of the current in a shunt (or series resistor). However I thought your problem was you wanted to increase the sensitivity not reduce it.
