Hello everyone,
My first post & and I'm a newbie to Arduino so forgive me if I'm being a bit stupid.
I've hooked up a ACS714 (-30A to +30A), a RTC and SD card onto my MEGA (also fitted with Ethernet Shield but removing it makes no difference) but am a bit perplexed as to why, with nothing connected, the sensorValue wanders around from about 506 to 511. I was expected a little fluctuation but around 0.4A seems a lot. I have my ACS board connected to my MEGA as follows:
OUT: A0
Vcc: 5v
GND: GND
Should I be using a resistor anywhere?
Is there a reference GND I should be using?
and finally do I have my maths right for calculating the mA readings - as hunting around the internet there seems to be several ways of doing this.
Any advice gratefully received...
Here's my code:
#include <LiquidCrystal.h> //For the LCD
#include <RTClib.h>// For the RTC
#include <Wire.h> //For I2C comms
#include <SdFat.h> // Include the standard SD card library
SdFat sd; //alias for the SD library
SdFile DataFile; //alias for the datalog file
const int chipSelect = 53; //Initialise the SD card outputs on the Arduino. Mega = 53
// initialize the LCD library with the numbers of the interface pins. You can use any (but wire to those specified obviously!)
LiquidCrystal lcd(22, 23, 24, 25, 26, 27); //LCD pins RS(4), DB4(11), DB5(12), DB6(13), DB7(14)
RTC_DS1307 RTC; //Initialise the RTC
int analogInPin = A0; // Analog input pin that the carrier board OUT is connected to
int sensorValue = 0; // value read from the carrier board
int outputValue = 0; // output in milliamps
String TimeString=""; //Used to concatenate the time & date string
int lastTime = -1; //Used to set a time interval
int led = 13;//LED to show logging
Serial.begin(9600); // initialize serial communications at 9600 bps:
lcd.begin(20, 4);// LCD set up. Set the LCD's number of columns and rows:
Wire.begin();//set off the I2C comand
RTC.begin(); //Start the RTC
//RTC.adjust(DateTime(DATE, TIME)); //Running this sets the RTC Clock via the controller PC
pinMode(chipSelect, OUTPUT); //Set SD Chip Select pin on the Arduino as output (even if not using this function)
pinMode(led, OUTPUT);
{digitalWrite(led, LOW);} // turn the LED off by making the voltage LOW
DateTime now = RTC.now(); //Get the Time
int time = now.minute();
// read the analog in value:
sensorValue = analogRead(analogInPin);
// convert to milli amps
outputValue = ((long)sensorValue - 512 ) * 73.982L;
//outputValue = ((long)sensorValue - 512 ) * 234375 / 4000000;
//outputValue = ( ((long)sensorValue * 5000 / 1024) - 2500 ) * 1000 / 66;
Analog read produces a value of 0-1023, equating to 0v to 5v.
With a sensitivity of 66 mV per A the optimized -30 to 30 range
would be (Vcc/2)-1.98V to (Vcc/2)+1.98V (0.52V to 4.48V).
That's something like .073982 A per step. 73,982 microamps per step.
// lcd.clear();
lcd.setCursor(0,0);
lcd.print(TimeString);
lcd.setCursor(0,1);
lcd.print(sensorValue);
lcd.setCursor(0,2);
lcd.print(outputValue);
if (abs(time - lastTime) >= 1)
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
//create the time string
TimeString=String(now.day(),DEC) + "/" + String(now.month(),DEC) + "/" + String(now.year(),DEC) + " "
- String(now.hour(),DEC) + ":" + String(now.minute(),DEC) + ":" + String(now.second(),DEC);
// print the results to the serial monitor:
Serial.print(TimeString);
Serial.print("Sensor Count (0-1023)= " );
Serial.print(sensorValue);
Serial.print("\t Current (ma) = ");
Serial.println(outputValue);
// Initialize SdFat or print a detailed error message and halt
// Use half speed like the native library.
// change to SPI_FULL_SPEED for more performance.
if (!sd.begin(chipSelect, SPI_QUARTER_SPEED)) sd.initErrorHalt();
// open the file for write at end like the Native SD library
if (!DataFile.open("ampleak.txt", O_RDWR | O_CREAT | O_AT_END))
sd.errorHalt("ERROR opening ampleak.txt for write!");
// if the file opened okay, write to it:
Serial.println("Writing " + TimeString + "," + String(sensorValue) + + "," + String(outputValue) + " to ampleak.txt...");
lastTime = time;
DataFile.println(TimeString + "," + String(sensorValue) + "," + String(outputValue));
DataFile.close();// close the file to complete the write process:
