My apologies if this is a "frequently answered question", but so far I can't find recent authoritative discussion.
As of IDE 1.8.12, and assuming something like a Mega2560 as the target, is there any advantage to messing around with PROGMEM and F() for simple output like below?
How does PROGMEM work with "stringize helpers" used to expand something like DATE?
I'm looking at a comparatively small amount of version info displayed at the start of a sketch run, but am assuming that the same principles apply to e.g. Serial.print() when it's outputting a menu with which the user will interact.
MarkMLl:
That would depend on how short you are of memory ?
Easy enough to test the impact of F() in the circumstances above on the amount of memory you have free.
I know it's easy to test, I'm asking what "best practice" is considered to be since I'm of the opinion that it's easier to plan for things like this early on rather than trying to fix stuff when a problem becomes apparent.
What does GCC (etc.) actually do here? Obviously the literal in something like
Serial.print("Hello World");
starts off in Flash, but is it copied into SRAM when the program starts and left there or is it copied temporarily to the heap or stack during execution of the print() (with F() eliminating that heap/stack overhead)?
Heap and stack are parts of SRAM. If you use F(), the strings are stored in flash from where they have to be loaded every time they are used - this causes less SRAM usage and slower execution. If you are not using F(), the strings stay in SRAM and are not moved - this uses more SRAM and executes faster.
If you are not running low on SRAM there is no point in using F().
MarkMLl:
I always (well, mostly) use the F-Makro especially on the UNO. It's easy when you start to write a sketch. It's a pain in the a.. if you have to adopt your code cause you are running out of memory.
Till now I encountered seldom cases where I need this last bit of performance. Nevertheless - in this seldom cases it's easier to revert some of the F-Markos when this last piece of performance is really needed, than to it vice versa.
Danois90:
Time overhead is negligible compared with the speed of a serial line.
But still: what's GCC actually doing? Are literal strings copied to SRAM and left there occupying precious space, or are they left in Flash until print() is actually called and then transferred to the heap or stack?
MarkMLl
(Who's spent 35 years selling/maintaining/supporting compilers).
//Uncomment the following line to use PROGMEM
//#define USE_PROGMEM
#ifdef USE_PROGMEM
#define FF(X) F(X)
#else
#define FF(X) X
#endif
Serial.print(FF("Should we use PROGMEM?"));
By making the code like this it is easy to switch between SRAM and PROGMEM by modifying a single line in the code.
MarkMLl:
When using F() the data remains in flash from where it is read byte-by-byte and used as such every time it is used. The data is never copied entirely to SRAM, unless your code does that - which would be counter-productive.
TheMemberFormerlyKnownAsAWOL:
Literals are copied to RAM during crt0 unless you use the F() macro or explicitly specify otherwise.
Thanks for that, exactly what I needed to know. So it's worth working out how to get something like FILE (which could be arbitrarily large) into PROGMEM.
noiasca:
there are interesting results if you play around with serial speed:
You cannot create a benchmark like that: 1) You cannot control how the compiler optimizes the code - statements may be executed in a different order as written in the code, and 2) Serial communication is buffered and when the buffer is full, execution blocks until the interrupt has transmittet enough data to make space for new data in the buffer.
noiasca:
Hmm. At the very least I'd suggest that you need to time how long it is before the buffer is completely flushed to the line i.e. I think you need something like
while (SERIAL_TX_BUFFER_SIZE - Serial.availableForWrite() > 1) ;
but that also raises the thorny question of whether the ISR is going to Flash and if so what the implications are.
Slightly off topic since it can never happen with an array, but I believe single byte literals can be stored in program memory and accessed with the LPM instruction. I would expect the compiler to use that ability whenever it can. The manual says of LPM, "This instruction features a 100% space effective constant initialization or constant data fetch". It takes 3 instruction cycles.
noiasca:
Why should I prevent optimization in this special circumstance?
Optimization will also be done in another sketch.
If you want to benchmark how long time a certain set of instructions take to complete, you cannot allow the compiler to mix and match - this will produce bad results.
Doing more work cannot take less time, so your benchmark is still flawed.
One thing you need to watch out for when using F(), when not using F() the compiler will look for identical string literals (such as printing the same text to an LCD and the serial monitor) and only store a single copy of the string in RAM, but does not do this when using F(), therefore you can end up wasting flash memory with multiple copies of the same string. Easy enough to get around this by storing the string in a char array in PROGMEM, then printing the array, when you know to watch for it.
An editor that uses regular expressions makes it much easier to find all the print/println statements and insert the F() macro around the string literal.
david_2018:
