Current source for LED.
I'm trying to vary current through a high power LED to vary its brightness. I wonder if there are any current sources that can be controlled with an arduino. Maybe I am overcomplecating and should find a small value pot to chain in series with a current limiting resistor. Is this a good idea?
BTW, I don't want to use PWM. Thanks.
Though you said you don't want to use PWM, have you considered smoothing it with a capacitor to make a DC voltage? That way you could change the voltage on the base of a transistor which changes the current through the LED. Just a thought.
Kyle
You can construct a current source in a variety of ways, using an adjustable voltage regulator for example (e.g., LM317).
But if you're OK with mechanical adjustment through a pot then that sounds easiest.
Not a good idea as a small value pot would have to be of a very high wattage to be able to cope. It’s even worse if you think you are going to use a digital controlled pot as the can’t handle anything approaching that much current.
PWM is just the turning on and turning off of a digital output.
You can use a digital pot but you’re still doing the same thing as PWM for more money.
http://www.maxim-ic.com/products/digi_pot/
You can’t use a transistor and resistor to do it as its fed by…yes PWM.
In fact you’ve made a crippling limitation on your design by denying PWM.
You could possibly use a resistor ladder
You can use a digital pot but you're still doing the same thing as PWM for more money.
Not sure I understand that. Digital pots work by switching in resistances arranged in chains with an analogue switch. Hence the limit on current.
