I'm trying to test a small application to integrate into my home automation but I get some weird results.
I want my led on pin 12 to go high for 500ms if input 8 goes high and 5000ms if input 7 goes high. The weird part is that it works but not on 500 or 5000ms, it takes longer.
If I look at the serial print I see first 10 to 12ms difference (interval) and then it starts.
What am I doing wrong because I'm missing something clearly.
Thanks for your help.
//Arduino PIR progamma test
long intervalrelay = 500;// Pulsbreedte voor het aansturen van de relais (milliseconds)
long Millis = 0;
long interval = 0;
void setup () {
//Initialize the serial port
delay (1000);
pinMode(12, OUTPUT); // sets the digital pin as output
pinMode(7, INPUT); //input PIR
pinMode(8, INPUT); //input drukknop
void loop ()
//Huidige milliseconden
//serial print for debugging
Serial.println(currentMillis);
Serial.println(Millis);
interval = currentMillis - Millis;
Serial.println(interval);
if (currentMillis - Millis > intervalrelay)
digitalWrite(12, LOW);
if (digitalRead(7) == HIGH)
digitalWrite(12, HIGH);
Millis = currentMillis;
intervalrelay = 5000;
if (digitalRead(8) == HIGH)
delay(10);
The first time your loop function detects the high it will send the output high. It will keep doing this while the input remains high, THEN the countdown begins. So you've got to add the time that the input is high to the begining of the countdown.
So i need to check when the state changes. Thats why even if I just make a small pulse it still is not right timing. It keeps thinking the output is high so he keeps filling currentmillis in millis.
So if previous state was low and current state = high --> Act!
So now I have update the program it works as intended but what I still don't understand is why does my input (digital read) stay high for about 7 seconds even if i just quickly tap a button (less than a second)
Is my arduino broken or something or is this normal behavior? Due to this I can't react within this 7 second window because he doesn't see any changes of course.
fyi, don't mind the delay of 500ms this is for debugging purposes.
unsigned long intervalrelay = 500;// Pulsbreedte voor het aansturen van de relais (milliseconds)
unsigned long Millis = 0;
long interval = 0;
int CurrentStatusPIR;
int CurrentStatusDKN;
int PreviousStatusPIR;
int PreviousStatusDKN;
void setup () {
delay (1000);
PreviousStatusPIR = digitalRead(7);
PreviousStatusDKN = digitalRead(8);
void loop ()
CurrentStatusPIR = digitalRead(7);
CurrentStatusDKN = digitalRead(8);
Serial.println("CurrentStatusPIR");
Serial.print(CurrentStatusPIR);
Serial.println(" ");
if (CurrentStatusPIR == HIGH && PreviousStatusPIR == LOW)
intervalrelay = 50000;
Serial.println("PreviousStatusPIR");
Serial.print(PreviousStatusPIR);
if (CurrentStatusDKN == HIGH && PreviousStatusDKN == LOW)
I don't understand why but it works like a charm. Do you force the input back down due to this resistor? And is this common practice because I didn't use this before
GeorgesVDR:
Yes it's more than common practice, it's practically prescribed practice. You shouldn't have an input "floating". So for things like buttons you'll have
EITHER
Input connected to GND via a resistor and then have the button apply 5v
OR
Input connected to 5v via a resistor then have the button apply GND
There are built in PULLUP resistors to support this second method. So if you connect your buttons to GND, then you can use the PULLUP resistor for the pin by setting its pinMode (pinNumber, INPUT_PULLUP); Using this method you don't need the external resistor, but your input will be active LOW (ie HIGH means button is NOT being pressed).
