Im planning on making something that pulls a fairly heavy "blackout" curtain at 5a and releases at 11p. This seems like a pretty simple project, but I'm intimidated by the Arduino ecosystem. Can anyone give a recommendation on models/accessories I'd need for this project? I'd like it to be battery powered and as small as possible. Thanks!
It would help if you define the requirements a little better. Can you take a fish scale and pull the drawstring to get an idea of the force required as a starting point? Then you have what you need to pick a motor and gearbox. Does the motor have to hold the curtain open (or closed)? Once you know which motor, then you can pick an H bridge motor driver to suit. Will there be limit switches at the ends of travel?
