Curtain Effect NeoPixel FastLED library
I'm trying to code a Curtain Effect for NeoPixel with the FastLED Library.
This is what I've managed so far:
 FastLED.setBrightness(50);
  // curtain effect
 for(int i=0; i<=75; i++) {
            leds[i] = CRGB::Blue;
            FastLED.show();
            delay(30);
        }                               // the 75th LED will be Blue
 for(int i=NUM_LEDS; i>75; i--) {
            FastLED.show();
            delay(30);                  // the 76th LED will be Blue
for(int i=75; i<=150; i++) {
            leds[i] = CRGB::Red;
            FastLED.show();
            delay(30);                // starting from LED #76, they will turn off oneoyone until the end
 for(int i=75; i<=75; i--) {
            FastLED.show();
            delay(30);               // starting from LED #75, they will turn off oneoyone until the start
  1. They all move separately. What would I need to do that the leds are filled in from both sides at the same time?
  2. The time until the next loop depends on the color. For Example, I count 8 seconds for Black, 5 if I choose Green and choosing Red repeats the loop after less than 1 second?? Does someone have an explanation?
Now after some research I discovered that some users suggest the use of an Array for this purpose. But I also found on a C++ tutorial website about loops that two variables are possible.
So I managed to modify the code to get the effect working
  // curtain effect
 for(int i=0, j=NUM_LEDS; i<=NUM_LEDS/2 && j>=NUM_LEDS/2; i++, j--) {
            leds[i] = CRGB::Cyan;
            leds[j] = CRGB::Cyan;
            FastLED.show();
            delay(30);
        }                               // the 75th LED will be Cyan
 for(int i=NUM_LEDS/2, j=NUM_LEDS/2; i>=0, j<=NUM_LEDS; i--, j++) {
            leds[i] = CRGB::Black;
            leds[j] = CRGB::Black;
            FastLED.show();
            delay(30);               // starting from LED #75, they will turn off onebyone until the start
while(1){}
Now I want this to run only once, hence why I put while(1){} in it, but for my project it is supposed to be interrupted by Sensor data, PIR Motion Sensor to be precise. I wonder whether this is interruptable by an event
