I have two programs, one for the receiver, and one for the transmitter. The transmitter should transmit an integer value from the Serial Input to the Receiver, which should receive it and send back a custom ack payload containing an integer.
The data transmission works fine, where the receiver gets the integer from the transmitter, but there is nothing on the ack payloads. Do you have any inputs or advice?
Thanks!
Transmitter Code:
// Load in the libraries
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
PAYLOAD -- KEY
* All integers
0 - CONTINUE. When everything looks normal, this continues normal operations of the flight computer.
1 - ABORT. Log the abort and current state to SD, then shut off all active control.
// Set the CE & CSN pins
#define CE_PIN 0
#define CSN_PIN 1
// This is the address used to send/receive
const byte rxAddr[6] = "00001";
// Create a Radio
RF24 radio(CE_PIN, CSN_PIN);
// Start up the Serial connection
while (!Serial);
// Start the Radio!
radio.begin();
// Power setting. Due to likelihood of close proximity of the devices, set as RF24_PA_MIN (RF24_PA_MAX is default)
radio.setPALevel(RF24_PA_MIN); // RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
// Slower data rate for better range
radio.setDataRate( RF24_2MBPS ); // RF24_250KBPS, RF24_1MBPS, RF24_2MBPS
radio.enableAckPayload();
radio.enableDynamicPayloads();
// Number of retries and set tx/rx address
radio.setRetries(15, 15);
radio.openWritingPipe(rxAddr);
// Stop listening, so we can send!
radio.stopListening();
// Set up a message and a timestamp to it using millis()
String str = Serial.readString();
int ackData;
if (str != "") {
str.trim();
int str_len = str.length() + 1;
// Prepare the character array (the buffer)
char char_array[str_len];
// Copy it over
str.toCharArray(char_array, str_len);
// Ace, let's now send the message
radio.write(&char_array, sizeof(char_array));
// Let the ourside world know..
Serial.print("Sent Message: ");
Serial.print( char_array );
Serial.println("");
if (radio.isAckPayloadAvailable()) {
radio.read(&ackData, sizeof(ackData));
Serial.print("Ack data recieved: ");
Serial.println(ackData);
Receiver Code:
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 8
PAYLOAD -- KEY
* All integers
0 - CONTINUE. Log continnue and current state to SD. When everything looks normal, this continues normal operation of computer.
1 - ABORT. Log abort and current state to SD, then shut off all active control.
2 - HOLD. Log halt and current state to SD, then stop all active control, while keeping data and configurations in-place.
// The tx/rx address
int ackPayload = 4;
// Start the serial
while(!Serial);
Serial.println("NRF24L01P Receiver Starting...");
// Start the radio, again set to min & slow as I'm guessing while testing theire really close to each other
radio.begin();
radio.setPALevel(RF24_PA_MIN); // RF24_PA_MIN ,RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
// Set the reading pipe and start listening
radio.openReadingPipe(0, rxAddr);
// Preload a custom ack payload
radio.writeAckPayload(0, &ackPayload, sizeof(ackPayload));
radio.startListening();
if (radio.available())
// the buffer to store the received message in
char text[100] = {0};
// Now read the message, old examples have done = radio.read(), that doesn't work anymore!!!
radio.read(&text, sizeof(text));
int payload = atoi(text);
// Print the message out to the COM window
Serial.println("Received Payload: ");
Serial.print(payload);
Serial.println("");
// Preload the next ack payload
ackPayload = 2;
