Custom Adafruit Thermistor Library
Hi All,
I'm in the process of making a custom library. This is my first crack at making libraries so I thought I would start with a code set I'm very familiar with:
My thermistors are reacting but the reading are not accruate at all. My libraries work when I put the RNOM, TNOM, BCOE, SRES parameters in the globals.h instead of feeding them through via the AC_Test.ino file ( I would rather do this for when I use this library for various other thermistors). I plan on continueing the development with this library (variables for NTC/PTC and other things) and making it public for others to use.
globals.h:
#pragma once
#ifndef ARDUINO_H
  #include <Arduino.h>
#endif
#define tms_period  10 //Ten millisecond period
#define NSAMP       5     // Number of smaples taken for average
thermistor.h:
#ifndef thermistor_h
#define thermistor_h
#include "globals.h"
class ThermADC
  public:
    ThermADC(uint8_t pin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES);
    uint16_t read();
  private:
    uint8_t pin; // analog input
    uint16_t RNOM;//nominal value of resistance of the thermistor at 25 *C
    uint8_t TNOM;//nominal temperature for 10kΩ resistance
    uint16_t BCOE;// Beta coeffiecient fo the thermistor
    uint16_t SRES;// Value of R1 in the voltage divider
    void setThermistorParameters(uint8_t pin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES);
    uint8_t getPin();
    uint16_t getRNOM();
    uint8_t getTNOM();
    uint16_t getBCOE();
    uint16_t getSRES();
#endif
thermistor.cpp file:
#include "thermistor.h"
ThermADC::ThermADC(uint8_t pin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES)
  setThermistorParameters(pin,RNOM,TNOM,BCOE,SRES);
uint16_t ThermADC::read()
    uint8_t i;
    uint8_t samp[i];
    for (i = 0; i < NSAMP; i++)
      samp[i] = analogRead(getPin());
      unsigned long current_millis_tms = millis();
      while(millis() < current_millis_tms + tms_period)
      // 10 millisecond delay
    float  average = 0;
      average += samp[i];
    average /= NSAMP;
    // convert the value to resistance
    average = 1023 / average - 1;
    average = getSRES() / average;
    // Convert resistance to the temperature value
    float steinhart;
    steinhart = average / getRNOM() ;             // (R/Ro)
    steinhart = log(steinhart);               // ln(R/Ro)
    steinhart /= getBCOE();                          // 1/B * ln(R/Ro)
    steinhart += 1.0 / (getTNOM()+ 273.15);        // + (1/To)
    steinhart = 1.0 / steinhart;              // Invert
    steinhart -= 273.15;                        // convert absolute temp to C
    float t = steinhart*(1.8) + 32;  // convert to *F
    return t;
void ThermADC::setThermistorParameters(uint8_t pin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES)
  this->pin = pin;
  this->RNOM = RNOM;
  this->TNOM = TNOM;
  this->BCOE = BCOE;
  this->SRES = SRES;
uint8_t ThermADC::getPin()
  return this-> pin;
uint16_t ThermADC::getRNOM()
  return this-> RNOM;
uint8_t ThermADC::getTNOM()
  return this-> TNOM;
uint16_t ThermADC::getBCOE()
  return this-> BCOE;
uint16_t ThermADC::getSRES()
  return this-> SRES;
.ino file:
#include <thermistor.h>
//Timer Variables
unsigned long current_millis = 0;
//Timer Definitions
#define sec_period  1000
//Thermistor: ThermADC [varible]([analog pin],[Thermistor nominal resistance],[Nominal Temperature],[Beta Coefficient],[Value of R1])
ThermADC t1(A0, 10000, 25, 3950, 10000);
ThermADC t2(A1, 10000, 25, 3950, 10000);
  //Timer/////////////////////////////////////////////////////////////////////////////////
  current_millis = millis();
  //Thermistor Readings////////////////////////////////////////////////
  float o= t1.read();
  float r = t2.read();
  //Print Statments
  Serial.print("Thermistor 1: ");
  Serial.print(o);
  Serial.println(" *F");
  Serial.print("Thermistor 2: ");
  Serial.print(r);
  while(millis() < current_millis + sec_period)
    // 1 second delay
Here is what the serial output is:
Thermistor 1: 8717.00 *F
Thermistor 2: 260.00 *F
Hello,
Your read method doesn't return a float but a uint16_t, so your variable t is converted from float to uint16_t (you should have a compile warning about that), that's why you see strange results
Thank you for responding, I have made changes to:
thermistor.h (changed uint16_t to float):
class ThermADC
  public:
    float read();
  private:
    uint8_t getPin();
    uint16_t getRNOM();
    uint8_t getTNOM();
    uint16_t getBCOE();
    uint16_t getSRES();
#endif
and the thermistor.cpp (same as the header file change):
float ThermADC::read()
    uint8_t i;
    uint8_t samp[i];
    float  average = 0;
      average += samp[i];
    average /= NSAMP;
    float steinhart;
    return t;
  this->pin = pin;
  this->RNOM = RNOM;
  this->TNOM = TNOM;
  this->BCOE = BCOE;
  this->SRES = SRES;
  return this-> pin;
  return this-> RNOM;
  return this-> TNOM;
  return this-> BCOE;
  return this-> SRES;
and the result are better but still slightly off (suppose to be 70 to 74, thermistor two was on my leg so that's why that reading is slightly higher):
Thermistor 1: 134.90 *F
Thermistor 2: 141.79 *F
Thermistor 1: 134.96 *F
Thermistor 2: 141.73 *F
Thermistors are not precision devices and there will be variation between them - some of the cheap ones you can buy are probably outside of spec anyway .
The other issue is the resolution of you measurement is limited ( 1 part in 1024- in fact far less as your analog signal won’t go from 0 to full scale ) . A resistor divider with a non linear device will have different resolution at one end of its scale.
A problem often occurs when using floats , logs etc that you think you are getting a higher resolution result than the basic “1024” resolution can provide .
A simple curve fit over the range of interest may give a better result.
It’s worth looking at the basic reading coming in from the A/D to see what you are actually getting. For testing you need some known accurate temperatures ( eg sensor in a thermowell in ice water mix, don’t forget boiling pt varies with altitude too ).
Another problem is self heating from the current put through the thermostat and lead resistance .
You are up against it for accuracy from a thermistor without calibration
Useful link
Finally different technologies such as DS18b20 can give a far better result
Thank you for your reply but it has nothing to do with what I'm asking. The question I asked has to deal with building libraries, not the performance of the thermistor or code that yields the result. I've be using the math used in the .cpp file for years (with slight changes that account for self heating) and have been very happy with the result. I have just been writing it within the skecth file rather than using a library. In fact, if you read my post, I do achieve the correct values if my parameters are put into the globals.h file and not pass through from the sketch.
Hi everyone,
I have figure out the issue.
When I declared my sample array, I declared it as an uint8_t and needs to be at least uint16_t. I also made other changes in the get functions (removed them). I also went ahead and added a self heating protection piece in there (the user has the ability to use a GPIO to power voltage divider circuit only when a reading needs to be taken or have the voltage divider constantly powered- subjecting it to self heating) . I will continue to work on this library to be used for any kind of thermistor and other circuits that are commonly used (not just a voltage divider going into an analog input) and post on my github page. Here is the new code set.
.ino file:
//Timer Variables
//Timer Definitions
ThermADC t1
  A0,     //analog input pin
  7,     //power GPIO (will go high when taking a reading, put -1 if the top of the voltage divider is tied to supply rail)
  10000,  //Thermistor nominal resistance
  25,     //Nominal Temperature
  3950,   //Beta Coefficient
  10000   //Value of R1 in the voltage divider
ThermADC t2
  A1,     //analog input pin
  6,     //power GPIO (will go high when taking a reading, put -1 if the  top of the voltage divider is tied to supply rail)
  analogReference(EXTERNAL);
  float o= t1.read();
  //Print Statments
  Serial.print(o);
  Serial.print(r);
    // 1 second delay
thermistor.h:
class ThermADC
  public:
    ThermADC(uint8_t pin, uint8_t dpin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES);
    float read();
  private:
    uint8_t dpin;  // Digital Power GPIO, helps with self-heating
    uint16_t RNOM; //nominal value of resistance of the thermistor at 25 *C
    uint8_t TNOM;  //nominal temperature for 10kΩ resistance
    uint16_t BCOE; // Beta coeffiecient fo the thermistor
    uint16_t SRES; // Value of R1 in the voltage divider
    void setThermistorParameters(uint8_t pin, uint8_t dpin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES);
#endif
thermistor.cpp:
ThermADC::ThermADC(uint8_t pin, uint8_t dpin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES)
  setThermistorParameters(pin,dpin,RNOM,TNOM,BCOE,SRES);
    uint8_t i;
    uint16_t samp[NSAMP];
    if(dpin >= 1)
      digitalWrite(dpin, HIGH);
      samp[i] = analogRead(pin);
    if(dpin >= 1)
      digitalWrite(dpin, LOW);
    float  average = 0;
      average += samp[i];
    average /= NSAMP;
    average = SRES / average;
    float steinhart;
    steinhart = average / RNOM ;             // (R/Ro)
    steinhart /= BCOE;                          // 1/B * ln(R/Ro)
    steinhart += 1.0 / (TNOM+ 273.15);        // + (1/To)
    return t;
void ThermADC::setThermistorParameters(uint8_t pin, uint8_t dpin, uint16_t RNOM, uint8_t TNOM, uint16_t BCOE, uint16_t SRES)
  this->pin = pin;
  this->dpin = dpin;
  this->RNOM = RNOM;
  this->TNOM = TNOM;
  this->BCOE = BCOE;
  this->SRES = SRES;
