Saw a voltage drop across an inductor, went :o , apparently my connecting things skills Abysmal and simply forgot to solder the connection.
From the how to use this forum sticky post:
If you consider the issue solved, please edit your original post (the first one in the thread) and add "[solved]" to the subject line. That helps people know the issue is resolved. Also please post the solution, whether you worked it out yourself, or if someone else helped you. A note that "this was solved by doing X" is very helpful to other people with the same problem. Thanks!
