Hi all, I have a Custom made board with the Atmega328pb chip and i had some issues earlier burning bootloader and specific sketches using the extra I2C pin. Fortunately i got lucky using another core, and can load bootloader and sketches, but when powered down, the board looses everything, and when powered up i need to burn bootloader again and sketch and keep the board on to use. I'm Currently using the MCUdude Minicore package build from Github to upload sketches. One thing i noticed is that, the burning of bootloader fails the first time then, next time it works.
Here is the first error
Arduino: 1.8.15 (Windows 10), Board: "ATmega328, Yes (UART0), EEPROM not retained, 328PB, BOD disabled, LTO disabled, External 16 MHz"
avrdude: Version 6.3-20201216
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf"
Using Port : COM16
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
AVR Part : ATmega328PB
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4745024
Firmware Version: 0.4611299
Topcard : STK502
Error while burning bootloader.
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
option enabled in File -> Preferences.
Then this is the proper bootload on second run
Using Port : COM16
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9516 (probably m328pb)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0b11110111"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0b11110111:
avrdude: load data efuse data from input file 0b11110111:
avrdude: input file 0b11110111 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0b11011110"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0b11011110:
avrdude: load data hfuse data from input file 0b11011110:
avrdude: input file 0b11011110 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0b11111111"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0b11111111:
avrdude: load data lfuse data from input file 0b11111111:
avrdude: input file 0b11111111 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
Using Port : COM16
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "C:\Users\user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex"
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against C:\Users\user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex:
avrdude: load data flash data from input file C:\Users\user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex:
avrdude: input file C:\Users\user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0f"
Writing | ################################################## | 100% 0.02s
avrdude: verifying lock memory against 0x0f:
avrdude: load data lock data from input file 0x0f:
avrdude: input file 0x0f contains 1 bytes
After this i can load sketches, and the board executes them while it is on, but then i have to restart this whole process after power off.
Someone please help, it's through this forum i was able to get help on the MCUdude Minicore suggestion
